11-09-2014 03:21 AM - edited 03-17-2019 12:51 AM
Just 2 simple questions this time for the Cisco community
If a cisco ephone-dn number changes, does this affect the phone having to re-register?
And one more please if I may.
Does a DID number have to be the same as the Cisco phone itself?
I think it does as it's purpose is to by-pass the receptionist in the company to go directly to the staff member
Please let me know
Solved! Go to Solution.
11-09-2014 04:54 AM
Yes, when you change the DN the phone will re-register.
You just need the DID to find the DN, which can be directly mapped or you can add a translation rule that makes the translation for you:
A good thread on this already:
https://supportforums.cisco.com/discussion/11466881/routing-inbound-dids-isdnpri-using-cme-v86
11-09-2014 04:54 AM
11-12-2014 02:55 AM
Sorry for late reply. Thanks Kevin :) :)
