02-28-2014 09:34 AM - edited 03-16-2019 09:57 PM
Currently out business is set to hit a call tree at 5pm. I need to change this to 6pm. We are running CUCMBE 8.6. I cannot seem to figure out where the setting is. Can anyone help me?
02-28-2014 09:43 AM
If you have no idea where you're doing this, check TOD on CUCM, the time periods and time schedule, or if you're involving CUC, the schedule from whatever you're hitting on that side.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
03-04-2014 11:32 AM
Thanks for the reply. But none of those tell me where to look exactly. where do I find TOD, etc? I have already checked through the menu's and havent found anything about it.
we are on the BE so we do have unity.
03-04-2014 11:34 AM
You can go thru the CCM config guides for TOD, or just search TOD on CSC and find all the references, and I believe also a video on the config.
java
03-04-2014 01:51 PM
Hi Todd.
Start to check under call routing --> class of control >>> time schedule and time period
You should find there what you are looking for.
Carlo
