Changing PhoneGuides for CCMUSER
HUSLMJW79
Beginner
Beginner
If a User opens his personal device configuration over IP Adress of CUCM he can download the manual or quick reference guid for his used telepone.
Because some changes about the button configuration we need to use another adjusted version of the manuals and update the link for the guide in ccmuser used.
- How can I upload new documents (pdf) to the PhoneGuides path which is used in the link in ccmuser?
- Where can I change the link for used manual in ccmuser?
I hope someone can help me!
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
You can't. You'll need to provide them the guides in some other way.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
HUSLMJW79
Beginner
Beginner
no ideas?!
Jaime Valencia
java
java
Recognize Your Peers
