10-14-2011 06:16 AM - edited 03-16-2019 07:31 AM
I have a new server that has been built using 8.5.1 and my customer needs it put on a different subnet.
Unfortunately every time I change the IP address and restart it the Cisco Unified CM Administrator page won't let me log in and comes up with a database error on screen. I have tried this process with the 8.5.1 and the new SU3 that I downloaded last night.
Is there anything I can do that will allow me to change the IP Address or do I have to rebuild it from scratch?
10-14-2011 06:30 AM
Are you following the document on how to do such task??
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_5_1/ipchange/ipchg851.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
10-14-2011 06:35 AM
Hi Steven,
I'm just curious, did you follow the steps in this doc exactly?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_5_1/ipchange/ipchg851.html#wp42666
Cheers!
Rob
10-14-2011 06:36 AM
Hahahahaha! Sorry Java ....I'm too slow as usual +5
Maybe I haven't had enough Coffee yet today!
Cheers!
Huff
10-14-2011 07:00 AM
I have tried changing the address from both the GUI and the CLI, but on restart I cannot login the CM Administration. This is a single server with no subscriber.
10-14-2011 07:25 AM
The server name was the IP address, when I changed that back to the servername and all the enterprise settings to the name rather than the IP address, the server now boots and lets me in.
