05-11-2014 10:49 AM - edited 03-16-2019 10:45 PM
I would like to be able to configure my IP phones to make and receive calls (outside my LAN). What is a cheap and easy way to do this? Add a vonage device, get a SIP trunk? Also would I need to configure my router as a gateway and install CME on it?
Right now my setup is:
WAN Modem ---> Cisco 2811 ---> Switch ---> CUCM 8.6
--->IP Phones
05-11-2014 11:00 AM
Vonage don't offer any SIP service for end users like that... if you want to play in your lab, get cheaper sip trunk.
Look at these websites
05-11-2014 11:04 AM
I have looked into that, but for the config part, do I add the SIP config on my router and then add a gateway in CUCM? Also do I need PVDM modules on the router as well? Sorry I am a bit new to VOIP and CUCM.
05-11-2014 11:15 AM
I got my SIP connection from SIP.US
Yes, you need to prepare your Router be a SIP Gateway first then connect with your CUCM.
Personally I am using for my CME not CUCM and haven't done it before but don't think it will be different.
Look at the below website for full SIP configuration from where you can get what you required for your own as per CUCM requirement.
http://www.adcapnet.com/blog/cisco-2800-isr-configuration-for-sip-voice-with-nat-and-firewall/
05-11-2014 11:41 AM
Would/Could you paste or email a copy of your config with sip.us?
05-11-2014 11:53 AM
Having PVDM issue with that router these days so it freez but you can get from the link or from Cisco website... just google it.
