Check Extension Mobility Login Status
Murali_DS
Is there any way to check the EM login status apart from the one in Cisco Reporting - System reports - Unified CM Extension Mobilty. this tool doesn't give me a exact picture seeing a discrepancy on the report and it is not quite updated.
Thx,
M
Terry Cheema
Either you can check from the CUCM - Actively logged in devices (From devices, Phones > from the upper right corner dropdown)
Ref: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/bccm-861-cm/b06phone.html#wp1373809
or
you can try to run the below SQL from CLI:
run sql select eu.userid, emd.logintime, emd.loginduration, emd.datetimestamp from extensionmobilitydynamic emd inner join enduser eu on emd.fkenduser_lastlogin=eu.pkid
-Terry
Please rate all helpful posts
Terry Cheema
or
-Terry
5 stars for the SQL Query.  Very helpful.
Hi Terry ,
Is it possible to get the previous login\logout report ?
