How can you check the heat (temperature) of a MCS-7825 (HP-based). We suspect maybe some issues with overheated equipment. Tried looking in the RMTP but found nothing there. Is there a command via SSH maybe?
From the console or SSH conection try:-
show environment temperatures
This should give you:-
ID Type Temp/Threshold
1 CurrentReading 22 C
1 LowerThresholdNonCritical 37 C
1 UpperThresholdNonCritical 38 C
1 LowerThresholdCritical 39 C
1 UpperThresholdCritical 45 C
1 UserThresholdNonCritical 38 C
1 UserThresholdCritical 45 C
You might also want to check 'show environment fans' while you there.
Hope this helps,
Craig
PLEASE RATE HELPFUL POSTS!
