CIPC / CCME Question
cjhunt
Does anyone specifically know whether there is a firmware parameter required for CIPC ("load" command) when running it with CCME?
I have doen a fair bit of digging and all I can see so far is that you can specify the phone type as "type cipc".
I understand that CIPC is basicaly an emulation of 7970, so isn't the 7970 load appropriate?
Chris
Rob Huffman
Hi Chris,
I have not setup CIPC with CME but according to the attached doc no firmware is required. Have a look;
Cisco IP Communicator 2.0
**No firmware required**
Cisco IP Communicator 2.0 is supported by Cisco CallManager Express 3.3 using Cisco IOS Software Release 12.4.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a00805f6cb4.html
Cisco IP Communicator Overview (CME)
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00806a7ffb.html#wp1010500
Use the normal phone provisioning commands. In the "type" command, use the "CIPC" keyword to identify this phone as a Cisco IP Communicator.
Hope this helps!
Rob
9 Replies 9
