05-02-2016 08:21 PM - edited 03-17-2019 06:47 AM
Hi All,
May I know if the latest version of CIPC is compatible to windows 10, or if not is there a workaround for it to work?
Appreciate your response,
05-02-2016 08:35 PM
I checked release notes of CIPC which says
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cipc/8_6_6/Release_Notes.html#id_22883
Cisco IP Communicator now supports Cisco Unified Communications Manager Release 10.5.2.
It should be supported with 8.6.6
regds,
aman
05-02-2016 09:39 PM
In addition to the nice info shared by Aman i would suggest that it appears that Windows 10 is not yet fully tested with CIPC. So, it may work but you can wait for the Windows 10 to be listed under the supported OS in the release notes
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cipc/8_6_6/Release_Notes.html#CIPC_RF_S2A2955C_00
Manish
01-28-2017 05:10 AM
It seems that CIPC version 8.6.6 is not compatible with windows 10. Most of the end users say that the CIPC changes state to not responding, so they have to close the application and run it again. How can this problem be solved?
01-28-2017 09:58 PM
Exactly, CIPC 8.6.6 not yet supported. Chick release note for this version.
06-19-2017 04:16 AM
04-25-2017 08:35 AM - edited 09-27-2017 10:53 AM
Two part answer as of a year later.
This answer is dated April 25, 2017 (2017-04-25)
This answer was updated September 27, 2017.
CIPC 8.6.6 documentation last update was September 2016.
8.6.4 was released in 2014.
8.6.5 was released in 2015.
8.6.6 was released in 2016.
IF Cisco keeps this schedule 8.6.7 might be released in Q4 of 2017.
...but don't hold your breathe
David
04-26-2017 09:32 PM
[+5] to David for sharing info.
regds,
aman
09-18-2017 11:50 PM
Maybe Cisco have Beta of CIPC 8.6.7 (working on Win 10 x64)?
Thanks!
09-19-2017 11:42 AM
Just dropping a note to keep interest here. Looks like currently the only current version of Windows not supported would be 64 bit Win 10.
09-26-2017 05:38 PM
Where did this statement about Windows 10 32-bit only come from?
I do not see this in the release notes which appear to state 32bit and 64 are both supported.
Here is the latest release notes as of checking today:
The first page states:
The following features have been added to Release 8.6.5 of Cisco IP Communicator:
The Requirements Table listed in the release notes Mentions 64-bit multiple times as shown below.
If 64-bit is not compatible, i would never be able to tell from the release notes.
Table 1 Minimum and Recommended Requirements for Cisco IP Communicator
Item
Description
Internal Hardware (Microsoft Windows 10) |
12-04-2017 06:56 AM - edited 12-04-2017 07:02 AM
So based on the release notes it appears that Win10 64 bit is supported? Is anyone actually using CIPC on Win10 64 bit to verify it truly does work? Has anyone ran into any issues with CIPC 8.6.6 on Win10 64 bit?
12-11-2017 09:00 AM
We have had a few issues with 8.6.6.0 crashing on Win 10 64-bit. TAC reviewed the logs and determined we were hitting these bugs:
CSCvc46415 – CIPC intermittent crash during use with version 8.6.6 in Windows 10.
CSCve25545 – CIPC crash in GIPS audio thread.
They supplied version 8.6.6.1 and we haven't had any issues since.
01-23-2018 07:10 AM
01-30-2018 12:32 PM
hi ,
did you get access to the file cipc 8.6.6.1 ES yet. pls let me know if you can share this.
tahnks
vijay
