01-17-2011 07:57 AM - edited 03-16-2019 02:54 AM
I am trying to install CIPC on a new windows 7 machine. When I go to the network tab, all the options are grayed out, and I can not change the network interface, or the name of the device.
The CIPC will be registered to a CM version 8.0.2.40000-1 installed on VM.
Thank you,
Scott
Solved! Go to Solution.
01-17-2011 10:11 AM
This is likely because you're not running it with administrative privledges. Try right clicking on it and selecting "Run as Administrator".
01-17-2011 10:11 AM
01-17-2011 12:19 PM
That did it!
Thank you!
