10-09-2012 11:22 AM - edited 03-16-2019 01:35 PM
Hi all, here I am again, with some probs.
The issue this time is that my CIPC phones will fail to register (Registration rejected security error) when I allocate them to a Device Pool.
The funny thing is, that i have one CIPC that is working just fine, on or off the device pool, all other 3 CIPCs are not.
As soon as I remove them from the pool and reboot them, they will register fine.
ps: this is in a lab enviroment only and I'm using CUCM 8.6
Any ideas?
thanks
10-09-2012 10:45 PM
Hi , pls check the capacity on Servers associated to device pool u allocate the CIPC .
10-10-2012 03:17 AM
Hi, I'm still quite new to all this.
How do I check that?
10-10-2012 03:42 AM
To solve Complete this procedure:
Procedure
Step 1 Make sure the LSC is installed under the personal certificate store. From Start > Run, enter
certmgr.msc.
Step 2 Select Personal > Certificates, and make sure the device name on the certificate matches the
Cisco IP Communicator device name (right-click > Preferences > Network tab > Device Name
section).
Step 3 For Cisco Unified Communications Manager Releases other than 4.x, on the Phone Configuration page,
click Reset to clear the configuration cache on the TFTP server.
For Cisco Unified Communications Manager Release 4.x, on the Phone Configuration page, click Reset
Phone to clear the configuration cache on the TFTP server.
10-10-2012 05:04 AM
I have already tried it and did not work.
When I go to my certificates, there is nothing under "Personal".
