Highlighted
CIPC Registration rejected with Secure Profile
I have the same Issue as mentioned in another discussion.https://supportforums.cisco.com/message/3772325#3772325
The CIPC is installed on a Laptop which is connected to the local LAN. The Trust-List is updated correctly, but the LSC-File is not downloaded and not installed on the Laptop. tried to install the Certificate manually, which was mentioned in the Thread above. But I don't know which certificates you have to add to the laptop. Or have I to "construct" a LSC-File manually?
CUCM: 8.5
CIPC: 8.6.2.0
Can someone help me?
Thank's a lot!
Matthias
8 REPLIES 8
Highlighted
Hall of Fame Master
Did you perform config Erase?  What message are you seeing in the status messages on the phone?
Chris
Highlighted
yes, I erased the config several times.
In the Statusmessages I see, that the Phone is updating its CTL-File but cannot update the LSC-File. The phone gets also its XML-Configfile from the TFTP.
Matthias
Highlighted
Softphones such as CIPC do not have a MIC so you must enroll them manually By Authentication String. Have you gotten through that process?
http://www.cisco.com/en/US/docs/voice_ip_comm/cipc/2_1/english/administration/guide/cag21pre.html#wp1045841
http://www.cisco.com/en/US/docs/voice_ip_comm/cipc/2_1/english/administration/guide/cag21pre.html#wp1045999
Please remember to rate helpful responses and identify helpful or correct answers.
Highlighted
I checked the configuration as you mentioned.
But now I have the problem, that I can configure what I want - secure or not secure profile - the registration is always rejected from CUCM. With the non-secure Profile the CIPC doesn't need a LSC-File, right? So it does not download it. But it cannot register at the CUCM and there is no LSC-File on the Computer.
I always see on the CUCM, when I add the CIPC as a new phone with this PC, that it rejects the phone immediately.
What wents wrong?
Thanks!
Matthias
Highlighted
it's really strange.
Now I have the Problem, that the CUCM does not register the CIPC any more. Even when I disable any security, the phone is still rejected when I add it as a new one. For testing I changed the MAC-Address of the Laptop - same issue. The phone is rejected.
Is there a Bug in the System?
Matthias
Edith: A dbreplication stop and dbreplication reset all solved the registration problem with the CIPC.
Highlighted
Here for other users,
the steps I made to secure the communication with CIPC.
1. Add CIPC-Phone without Secure-Profile
2. Change the Secure-Profile to "Authenticate with String"
3. CAPF-Configuration to "Install/Upgrade" and "By authentication String"
4. Create a String or press the "Generate String"-Button
5. On CIPC go to "Security Configuration"
6. LSC (unlock administration) and press "Update"
7. Enter the String, which was generated before
8. The LSC-File is downloaded now
9. After that you can switch the Security-Configuration to "Authenticate by LSC"
Matthias
Highlighted
it is the very interesting topic and I have the great interest in gaining the knowledge about it.If you have any issue regarding your laptop screen in dubai just visit the site
Highlighted
Beginner
Please help me find the solution for the same problem. And if you are facing and issue with laptop screen you can visit us.
Content for Community-Ad
