Cisco 1720 Router Ear to Mouth VIC 2 to UC520 question
keith Kress
Hello.
I have a UC520 that has a malfunctioning MOH port. i have a Cisco 1720 Router and E/M card i can install
in the 1720. so my question is can i set up music on hold from a live feed E/M port on the 1700 to use on my UC520?
Brandon Buffin
You might be able to make this work using multicast MOH hold from the 1720. See this link.
http://www.netcraftsmen.com/live-stream-music-on-hold-and-cisco-uc-on-ucs/
Do you have a free FXO port on the UC520? Looks like it is also possible to use this port as a live feed. The following doc references CME. Since the UC520 is essentially CME on a purpose built box it should work. I have not tested to verify.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmemoh.html#concept_9B98C5B487894D209109D16858F0A533
Brandon
that is great thank you for your reply
