Highlighted
Beginner
Cisco 1760 Flash
I would like to load some backgrouds to our 1760 for use by the 7970 IP Phone.
I know I need to add a folder with the images and xml file.
However, looking at the current flash of our router, we do not have folders/subdir for anything. How do you add one?
Router is running CME 4.0
Thanks.
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Cisco 1760 Flash
2 REPLIES 2
Highlighted
Hall of Fame Master
Cisco 1760 Flash
Highlighted
Beginner
Cisco 1760 Flash
Thank You.
So, now that I have all the images and XML in the root of the flash. I should be able to use the alias command, to make this work?
"Place all the files in the root directory and use the TFTP alias statement to create the illusion of the correct structure.
For example;
tftp-server flash:/7971-ColourBG.png alias Desktops/320x212x12/7971-ColourBG.png"
