03-13-2012 07:53 PM - edited 03-16-2019 10:06 AM
I am trying to enable the CME GUI on an 1861E but am having great difficulty. I uploaded what I thought were the necessary files into flash but when I attempt to access the GUI I get a page that is missing items.
If someone could spell out the process more clearly that Cisco documentation on how to enable the GUI & which files need to be loaded into flash, it would be greatly appreciated.
Thanks in advance.
DC
03-13-2012 09:07 PM
Attach Configuration of CME please. Also let us know what broswer you are using.
Ronak Patel
03-25-2012 07:07 AM
Hi Ronak,
Sorry for the late response. I did not receive a notice that anyone responded. In any case, here is the Config:
Router>enable
Router#show run
Building configuration...
Current configuration : 2690 bytes
! Last configuration change at 22:17:14 pst Tue Mar 13 2012 by admin
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone pst -4 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
dot11 syslog
ip source-route
ip cef
ip dhcp pool VOICE
network 192.168.100.0 255.255.255.0
option 150 ip 192.168.100.1
default-router 192.168.100.1
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
voice-card 0
license udi pid C1861E-SRST-C-F/K9 sn FTX160785RZ
username admin privilege 15 secret 5 $1$JrE1$4a.BJGAPS8kcHVqE3mle80
interface FastEthernet0/0
description $ETH-WAN$
ip address dhcp client-id FastEthernet0/0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Integrated-Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
switchport access vlan 10
interface FastEthernet0/1/8
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
ip nat inside source list 1 interface FastEthernet0/0 overload
logging esm config
access-list 1 remark INSIDE_IF=Vlan10
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.10.0 0.0.0.255
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
mgcp profile default
telephony-service
max-conferences 4 gain -6
web admin system name admin secret 5 $1$f/jG$YCw36SDn2AsSyadA9xvqI/
dn-webedit
time-webedit
transfer-system full-consult
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login
transport input all
ntp server 192.43.244.18
end
I am running IE 9
Thanks again,
DC
03-25-2012 08:24 AM
This is asked quite often. IE9 doesn't work with CME GUI. Use Firefox or older IE.
03-25-2012 11:11 AM
Hi Paolo,
Good to know....thank you. Unfortunately though, it did not resolve the issue. I get the logon box, login & I am presented with the screenshot above & non of the hyperlinks work.
DC
03-25-2012 11:18 AM
Make sure you are using the right files.
Copy files to a directory, configure it with "ip http path".
03-25-2012 11:33 AM
I think that may very well be my issue. Which files would in fact be the "right files" for my version of IOS? I copied the files within the CME 8.5.0 GUI folder to flash. See image....
03-25-2012 12:26 PM
So you only have to configure it right.
You would have saved time by searching before asking.
03-25-2012 12:35 PM
You're losing me here, Paolo. What you see above is what I had done prior to posting on this forum & it is NOT working. So my question is, what am I missing? I have followed Cisco's documentation for setup & the result is a CME GUI that does not work. The logon box comes up, I enter the WebAdmin username & pw that I setup in CLI & all I get is a webpage that will not fully load.
So that being said, do you or anyone else have some insight to what I may be missing?
thank you,
DC
03-25-2012 12:45 PM
I think you have not read my post above.
