11-14-2011 01:00 PM - edited 03-16-2019 08:03 AM
I'm getting conflicting info from TAC regarding a 1941 router supporting voice. Can anyone confirm or deny that a 1941 does in fact support voice? I need to make it a H323 gateway.
Thanks.
Solved! Go to Solution.
11-14-2011 04:31 PM
You can NOT use a 1941 as a voice gateway.
It does not have PVDM/DSP support
It is an ISR but it is aimed at the routing/WAAS/Wireless arena
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/data_sheet_c78_556319.html
You could look at a 2901
http://www.cisco.com/en/US/prod/collateral/routers/ps10537/data_sheet_c78_553896.html
Or find a 28/38xx series
Alex
11-14-2011 04:31 PM
Alex
11-14-2011 09:02 PM
To add to Alex's response, I would like to mention that 28xx/38xx are end of sale products & hence Cisco doesnt have any plans to enhance them to accomodate new features. Cisco recommends going with ISR G2s i.e. 29xx/39xx.
GP.
02-10-2020 08:02 AM
can i use vfo card with 1941
