cisco 2610XM integration via E1 with siemens hipath 3750 with TMS2
essaki_ihssan
Hello;
I have a Siemens HiPath 3750 with TMS 2 card set with a protocol (S2M: Euro-ISDN PP WITH CRC4 Euronumeris = T2 + (ETSI) WITH CRC4) to make a connection with a cisco router 2610XM with IOS (c2600-ipvoice-mz.124-25) via an E1 card.
WHat protocol should I use cisco router side.
I ask if i can have a configuration example for this integration because I do not know if I should use the isdn switch-type on Net5 or QSIC, and the E1 controller configuration, and serial interface.
Thank you in advance for your help.
Regards.
acampbell
Hi.
This will be Net5
Have a look through this document some of this may be similar to what you are looking for
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/465547nt.pdf
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
