10-25-2011 09:41 AM - edited 03-16-2019 07:41 AM
Hi All,
I want to check whether Cisco 2620 is support for voice gateway and call manager ? I know that 2611XM is supported.
10-25-2011 10:11 AM
It would, but it's such and old, slow and limited model, that you don't want to loose any time with it.
10-25-2011 07:32 PM
Hi Paolo,
Is there any matrix table for router requirement voice gateway, cause I couldn't find it. Have you try 2620 as a voice gateway before ?
10-26-2011 03:36 AM
All the information that you need can be found on cisco.com, or consult a Cisco Reseller.
As mentioned before, a 2620 today is essentially useless.
