CIsco 2811 Gatekeeper command
Curtis Fuentes
   I am working on my CCIE voice lab at home, but I am not able to enter the Gatekeeper command in my cisco 2811 routers. I am running IOS 12.4(15)
Thank you for the help in advance.
I believe you can get a demo license file from cisco..
https://supportforums.cisco.com/thread/2195933
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
6 Replies 6
Aman Soi
Hi Curtis,
what is the image feature u are using?
you should have image like c2800nm-ipvoice_ivs-mz.124-23b.bin
regds,
aman
Ayodeji Okanlawon
Curtis,
Depending on what 12.4.15 release you are, this may be a license issue.. Please refer to this thread..
https://supportforums.cisco.com/thread/1002164
Is there any way to get this done without purchasing a license. This is for a lab environment not production.
Thank you
Thank you
Hi Curtis,
Had a similar issue in my lab , I did want the license. Instead i downgraded the IOS and without the demo license.
The below IOS does not require gatekeeper license:
"flash:c2800nm-ipvoice_ivs-mz.124-4.T7.bin"
Cisco IOS Software, 2800 Software  (C2800NM-IPVOICE_IVS-M), Version 12.4(4)T7, RELEASE SOFTWARE (fc1)
Technical  Support: http://www.cisco.com/techsupport
Copyright  (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 28-Nov-06 18:37 by  kellythw
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE  (fc1)
HQ uptime is 2 weeks, 4 days, 12 hours, 27 minutes
System  returned to ROM by reload at 07:28:44 PST Fri Jan 24 2014
System restarted at  07:29:49 PST Fri Jan 24 2014
System image file is  "flash:c2800nm-ipvoice_ivs-mz.124-4.T7.bin"
Kidnly rate the post accordinly.
Kevin
