We are having issue with itsp sip trunk. We are able to send register request but right after registration completes with 3600 timer, right in next register message shows timer 0. And registration stuck. Here is the scenario.
ITSP-->Cisco 2811-->CUCM
I tried this thing with one other router as well but same issue happening. Further we got bug for same issue so upgraded to 15.1(4)M8 to 15.1(4)M10. But issue remains same.
We need to block second register timer 0 message. Kindly suggest. Configs and logs attached for reference.
For reference register request and register timer 0 shared below as well.
Sent:
REGISTER sip:vodafone.qa:5064 SIP/2.0
Via: SIP/2.0/UDP 10.72.0.194:5060;branch=z9hG4bK2010CB
From: <sip:+97440006999@vodafone.qa>;tag=2033E4-1F67
To: <sip:+97440006999@vodafone.qa>
Date: Tue, 06 Oct 2020 14:39:17 GMT
Call-ID: 8C1D64C1-71811EB-8098FF03-3350B16D
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1601995157
CSeq: 3 REGISTER
Contact: <sip:+97440006999@10.72.0.194:5060>
Expires: 3600
Authorization: Digest username="97440006999@ims.vodafone.qa",realm="vodafone.qa",uri="sip:vodafone.qa:5064",response="c091fae58b5996cefe65a310f74cf83f",nonce="b75f7c8599c9036dbf3054aea940e9703dc8f84c0208",opaque="ALU:QbkRBthOEgEQAkgVEwwHRAIBHgkdHwQCQ1lFRkdWCB4icyonNnZ2ZiAnOGI7ISsxNz09MXs1ODV3K1AIBgQCBg__",cnonce="7F771DC9",qop=auth,algorithm=MD5,nc=00000001
Content-Length: 0
Oct 6 14:39:17.683: //430/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <sip:+97440006999@vodafone.qa>;tag=SDaajmc99-5da7ac98-5f7c859a18b25db0
CSeq: 3 REGISTER
Allow-Events: reg
Authentication-Info: nextnonce="d2f71bdd94e4a4504da35d8c15f7c8598aeec4426085", qop=auth, rspauth="c091fae58b5996cefe65a310f74cf83f", cnonce="7F771DC9", nc=00000001
Contact: <sip:+97440006999@10.72.0.194:5060>;expires=3600
Date: Tue, 06 Oct 2020 14:56:26 GMT
P-Associated-URI: <sip:+97440006999@vodafone.qa>
P-Associated-URI: <tel:+97440006999>
P-Associated-URI: <tel:+97440006900;wcard-range=+974400069![0-9][0-9]!>
P-Associated-URI: <sip:+974400069![0-9][0-9]!@vodafone.qa>
Server: Alcatel-Lucent-HPSS/3.0.3
Service-Route: <sip:+97440006999@172.16.9.4:5064;transport=udp;lr>
Content-Length: 0
Oct 6 14:39:17.695: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.72.0.194:5060;branch=z9hG4bK21FF4
From: <sip:+97440006999@vodafone.qa>;tag=203424-1518
Max-Forwards: 70
CSeq: 4 REGISTER
Expires: 0
Supported: path
Content-Length: 0
