ā10-23-2013
02:41 PM
- last edited on
ā03-25-2019
08:26 PM
by
ciscomoderator
Hello all,
I recently purchased a 2851 for my home lab and it is running 15.1 advanced enterprice. I purchased a VIC2-FXO (which according to the docs that card is supported), and when I do a show diag it is being detected with no errors, however when I do a show run, it dows not show up and physically the card has 2 solid amber lights. This router does not have any DSP modules currently installed. I was hoping someone could tell me if this might me and IOS issues, though I though advanced enterprise did support voice cards, or simply something that can be resolved by adding DSP modules.
-Jeff
Solved! Go to Solution.
ā10-23-2013 02:50 PM
sounds like you don't have PVDM's in the router. Your VWICs will not come up without them.
Thank you
Please rate all useful information
Thank you
ā10-23-2013 05:10 PM
Correct, FXO without PVDMs is useless.
Chris
ā10-25-2013 03:11 PM
Hey Guys,
Thanks for the the info. Thats what I suspected. Every router I have bought in the past had the PVDM's pre-installed so I never noticed it. I ordered a few and they are on the way.
-Jeff
ā10-25-2013 03:18 PM
Hi Jeff
No problem my friend , please do not forget to rate all correct answers. You are welcome any time.
Thank you
please rate all useful information
ā10-25-2013 09:13 PM
PVDM2 on the market have become much more affordable since 29XX and PVDM3 were released. I think now is a good time to build a decent home lab
ā10-25-2013 10:00 PM
Hi Jeff,
This is because you would have ordered Voice loaded/bundled router that is the reason router comes pre-loaded woth Voice IOS along with PVDMs.
Possibly, you have decided to use 2851 now as a voice box.
regds,
aman
