11-04-2015 06:50 AM - edited 03-17-2019 04:48 AM
I'm currently working on a getting a Cisco 2901 to work as a voice gateway with a HWIC-4B-S/T. It's running IOS 15.0(1r)M16 (c2900-universalk9-mz.SPA.154-3.M3.bin).
In order to route my calls to the correct BRI ports, I need to assign a port (voice-port) to the pots dial-peer. In my old Cisco 2801 config it looked like this:
dial-peer voice 100 pots
preference 1
destination-pattern 0.!
port 0/0/0
Which points to the voice-port:
voice-port 0/0/0
translation-profile incoming FROM_ISDN
translation-profile outgoing TO_ISDN
no vad
compand-type a-law
cptone NL
But in with this new Cisco 2901 I don't get to see the "voice-port 0/0/0". I already tried looking it up within the IOS documentation and other Cisco doc's. But no luck.
show inventory ouput:
NAME: "CISCO2901/K9", DESCR: "CISCO2901/K9 chassis"
NAME: "4-port Wan Interface Card BRI S/T on Slot 0 SubSlot 1", DESCR: "4-port Wan Interface Card BRI S/T" HWIC-4B-S/T
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
Regards, Paul
Solved! Go to Solution.
11-04-2015 07:53 PM
Hi Paul,
you need to have VIC2-2BRI-NT/TE card for voice functionality.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/ip-communications-voice-fax-network-modules/product_data_sheet0900aecd801c595e.html
the ISDN card which which u are using is for Data.
regds
aman
11-04-2015 07:53 PM
Hi Paul,
regds
aman
11-04-2015 11:29 PM
Thanks Aman!
11-05-2015 01:48 PM
Nice!!! prutser!
