Cisco 2901 - Media Anti-Trombone disappearing after reboot
chawkins89
Beginner
Beginner
Hi Cisco Community Support,
We have an issue where internally forwarded calls to external are not receiving RTP, this was rectified by using the following commands:
voice service voip
media anti-trombone
However, even after having saved the configuration the command appears to disable itself after a reboot and has to be re-applied.
The device is a 2901.
The IOS version is: 151-4-M4
Can anyone confirm as I have looked through the documentation on this but have failed to find anywhere that explicitly defines that this command is dropped upon reboot.
Any help will be greatly appreciated.
Christopher
Nipun Singh Raghav
Sounds like a defect. Can you upgrade to a latest release and see if the issue is still there ? The command was added to IOS starting 15.1(3)T. It might still be new on the code and have issues.
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Thank you for the prompt response, if the IOS is upgraded will we need to re-host the license at all to support that version?
Christopher
Nope, you don’t need to do anything. Rehost is usually
done when you are moving b/w platforms i.e S/N changes.
Nipun Singh Raghav
Thank you for your response, I will look into getting this done and let you know if it resolves.
Christopher
Recognize Your Peers
