09-03-2015 12:52 AM - edited 03-17-2019 04:12 AM
Hi experts,
I am being tasked to configure a voice router in which I am totally new at. I need some advice on where to start, i do not need the entire configuration by you guys (because that's too much to ask for) but need some guidance.
Attached here is the bill of material:
1 | CISCO2911/K9 | Cisco 2911 w/3 GE 4 EHWIC 2 DSP 1 SM 256MB CF 512MB DRAM IPB | 1 | Qty |
1.1 | S29UK9-15401T | Cisco 2901-2921 IOS UNIVERSAL | 1 | Qty |
1.2 | SL-29-UC-K9 | Unified Communication License for Cisco 2901-2951 | 1 | Qty |
1.3 | FL-CME | Cisco Communications Manager Express License | 1 | Qty |
1.4 | FL-CME-SRST-25 | Communication Manager Express or SRST - 25 seat license | 1 | Qty |
1.5 | VIC2-4FXO | Four-port Voice Interface Card - FXO (Universal) | 1 | Qty |
1.6 | ISM-SRE-300-K9 | Internal Services Module (ISM) with Services Ready Engine | 1 | Qty |
1.7 | SCUE-ISM-8.6-K9 | Cisco Unity Express Release 8.6 | 1 | Qty |
1.8 | FL-CUE-NR-PORT-2 | Unity Express License - Non Re-hostable - 2 Port | 1 | Qty | |
1.9 | CUE-LANG-ENU | Cisco Unity Express - North American English | 1 | Qty |
1.10 | PVDM3-16 | 16-channel high-density voice and video DSP module |
The scenario is as such:
PSTN -> Cisco 2911 Router -> Cisco 3650 IP Base Switch -> AP -> 4x Cisco 7925G wireless phones
Context:
1. This company has only 1 phone number. When users call into this number, all phones will ring (is it possible to have multiple extensions for this case?)
2. although 1 user is engaged in a call, other users still can use the phones (e.g. still accept new incoming and make outgoing calls)
3. There is no fax and no other uses for this router, only serving the telephony network for this project.
4. The DHCP server will be in this router, serving IP addresses to the wireless phones only.
Above is the scenario for this task, it will be very helpful if experts here can shed light on this. Thank you for reading this and do let me know if I have missed out any information.
Solved! Go to Solution.
09-04-2015 02:38 AM
Hi Marcus,
Do i need to include the dial-peer on the FXO for the incoming calls and outgoing calls? Yes
any voice translation to be configured if there are no extension numbers? Yes, you can configure to strip or match the digits of pilot number or shared line.
HTH,
Tirtha
09-03-2015 02:00 AM
Hi Markus.
The below link is a good starting point.
It will lead you through all CME features and how to configure them (including DHCP definition)
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmeplan.html
Carlo
09-03-2015 02:53 AM
Hi Carlo,
thanks for the link which is a very good starting point to follow as a newbie. I will go through it in detail soon and will post any queries.
09-03-2015 02:34 AM
Hi Marcus,
1. As the licenses here in BOM are for CME, I am considering this as a CME setup on Cisco 2911 Router
Two scenarios(see what suits you best)
4 phones have 1001,1002,1003,1004
OR
All phones have 1001 as a shared line
For share lines(Parallel Hunt Groups (Call Blast))
ephone-dn 1 octo-line
number 1001
ephone 1
type 7925
button 1:1
mac-address aaaa.aaaa.aaaa
ephone 2
type 7925
button 1:1
mac-address aaaa.aaaa.aaax
ephone 3
type 7925
button 1:1
mac-address aaaa.aaaa.aaay
ephone 4
type 7925
button 1:1
mac-address aaaa.aaaa.aaaz
Without shared line, 1000 is the Pilot number
voice hunt-group 4 parallel
pilot 1000
list 1001, 1002, 1003, 1004
number 1001
ephone-dn 2 octo-line
number 1002
ephone-dn 3 octo-line
number 1003
ephone-dn 4 octo-line
number 1004
ephone 1
type 7925
button 1:1
ephone 2
type 7925
button 1:2
ephone 3
type 7925
button 1:3
ephone 4
type 7925
button 1:4
For CUCM, we can use HP(1000)>>HL>>LG(Broadcast to any phone)
Note : I did not had a chance to test the complete configs. Please test and see if this works.
Here are few links for your help:
CME
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmecover.html#pgfId-1145800
http://www.ciscopress.com/articles/article.asp?p=401648&seqNum=2
CUCM :
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/4_2_3/ccmfeat/ccmfeat/fsccmac.html#wp1144539
Please rate the helpful posts
09-03-2015 02:52 AM
Hi Tirtha,
thank you for the guide in this, very much appreciated. I will only test this on Monday. Will definitely post the outcome.
09-04-2015 02:25 AM
Hi Tirtha,
octo-line is the way to go. Do i need to include the dial-peer on the FXO for the incoming calls and outgoing calls?
Also, any voice translation to be configured if there are no extension numbers?
Thanks for you help!
09-04-2015 02:38 AM
Hi Marcus,
HTH,
Tirtha
10-14-2015 08:39 PM
Hi Tirtha,
thanks for the guidance. I have successfully configured the phone system using CME and dialing the public phone number will trigger all phones with extension 1001 to ring at the same time.
Now I just need to do some tweaking, 2 tweaks to be specific. 1. When the main line is in use, when another caller is dialling the public phone number, the public user will hear a ringtone but the IP phones (the ones that are not in use) does not ring.
2. When the main line is in use by an internal user, another internal user is not able to make a new call. How to make this possible?
10-14-2015 10:05 PM
Seems you're using analog trunk (/FXO). If its so, analog trunk can handle only one call at a time. Hence there is one answer for both of your questions. When analog trunk is busy, neither internal user can make new call and nor external callers can make a call to your PSTN number. However there is an exception of call waiting if supported by your TELCO. If supported and external caller tries to call your PSTN number, your internal user will get call waiting beeps.
- Vivek
