Cisco 2921 CME SIP Trunk 503 Error
prabhu050446
Greetings Everyone,
I am trying to implement SIP trunk thru our current data circuit with below call flow. I was able to get the SIP registration with SIP carrier and when I make a inbound call from my cell phone to one of the SIP carrier provided DIDs then I get fast busy. I was able to capture the packets on my CME and I see call coming thru with my number but I see 503 Service Unavailable Reason: Q.850;cause=0. I cant make outbounds calls either.
Call Flow: Polycome phones -----> Core Switch -----> Cisco 2921 (CME Router) ----> Cisco 4451 NAT/Zone Based Firewall Router -----Internet ------> SIP Provider.
Below are the partial logs.
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 162.a.b.235:5060;branch=z9hG4bK+5ceb53914a0a9aed47588b4769016cb81+sip+1+ce9a230
From: "MY NAME" <sip:myphone#@sipcarrier.com>;tag=162.a.b.235+1+406ebbd6+44e1ece9
To: <sip:425DIDNUM@sipcarrier.com>
Date: Wed, 04 Sep 2019 01:09:13 GMT
Call-ID: 0gQAAC8WAAACBAAALxYAAEQA5PNDkXejjvgwUzjPl9EJnrfVKPIMbJ6o6XcjghR4@162.a.b.235
CSeq: 1028103836 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-16.7.1
Session-ID: 00000000000000000000000000000000;remote=6a257bd32e3150f5ad04e48ddf0027b7
Content-Length: 0
SIP/2.0 503 Service Unavailable
To: <sip:425DIDNUM@sipcarrier.com>;tag=71D1BF77-ADB
Content-Length: 0
Any suggestions are appreciated.
Thank you
Prabhu
10 Replies 10
Rodrigo Garcia
Can you share your CME configuration?
Hi Rodrigo,
Thank you for the response. Please find below the config.
voice service voip
ip address trusted list
ipv4 SIP CARRIER IP 1
ipv4 SIP CARRIER IP 2
ipv4 Phones LAN Subnet
ipv4 WAN Interface IP Address
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0/0
bind media source-interface GigabitEthernet0/0/0
registrar server expires max 600 min 60
outbound-proxy dns:sipcarrier.com
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
codec preference 4 g729r8
voice iec syslog
voice register global
mode cme
source-address 10.109.205.20 port 5060
max-dn 60
max-pool 60
authenticate register
authenticate realm sipcarrier.com
create profile sync blahblah
auto-register
dial-peer voice 200 voip
description Incoming dialpeer from SIP Carrier
translation-profile incoming 1
media monitoring
session protocol sipv2
session target dns:sipcarrier.com
incoming called-number .T
voice-class codec 1
no voice-class sip early-offer forced
voice-class sip options-keepalive up-interval 12 down-interval 65 retry 3
voice-class sip pass-thru content sdp
voice-class sip bind control source-interface GigabitEthernet0/0/0
voice-class sip bind media source-interface GigabitEthernet0/0/0
dtmf-relay rtp-nte sip-notify
dial-peer voice 210 voip
preference 2
destination-pattern [2-9]..[2-9]......
media monitoring
session target sip-server
incoming called-number 9T
voice-class codec 1
voice-class sip outbound-proxy dns:sipcarrier.com
fax-relay ecm disable
fax protocol pass-through g711ulaw
ip qos dscp ef signaling
no vad
authentication username DID# password 7 password realm sipcarrier.com
num-exp 1087 7020
num-exp 1086 7171
num-exp 1088 7050
num-exp 1090 7030
num-exp 1089 7060
sip-ua
credentials username DID# password 7 password realm sipcarrier.com
nat symmetric role active
nat symmetric check-media-src
no remote-party-id
retry invite 2
retry response 3
retry bye 3
retry prack 6
retry register 2
timers expires 300000
timers connect 100
registrar dns:sipcarrier.com expires 3600
sip-server dns:sipcarrier.com
connection-reuse via-port
host-registrar
Thank you
I can see both To and From fields have a @sipcarrier.com URI. I understand you are masking the IP addresses with @sipcarrier.com so, was this log copied/masked correctly? The To field should not have the sip carrier IP address in the URI but your CME IP address.
Yes, masked correctly but those debugs last 2 messages, some more debug messages below.
10.109.205.20 is my CME IP address.
REGISTER sip:sipcarrier.com:5060 SIP/2.0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKA365
From: <sip:425DIDNUM@sipcarrier.com>;tag=71D0E4B2-1AF2
Date: Wed, 04 Sep 2019 01:08:17 GMT
Call-ID: 5029FE2C-FFFFFFFFCDE711E9-FFFFFFFFB0EEC665-411FD79F
User-Agent: Cisco-SIPGateway/IOS-16.7.1
Max-Forwards: 70
Timestamp: 1567559297
CSeq: 2 REGISTER
Contact: <sip:425DIDNUM@10.109.205.20:5060>
Expires: 3600
Supported: path
Content-Length: 0
SIP/2.0 401 Unauthorized
CSeq: 2 REGISTER
To: <sip:425DIDNUM@sipcarrier.com>;tag=sip+2+c6a9009a+17f71efd
Content-Length: 0
WWW-Authenticate: Digest realm="sipcarrier.com",nonce="9a97234eec80",stale=false,algorithm=MD5,qop="auth"
Server: DC-SIP/2.0
Organization: Metaswitch Networks
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKB14CA
Date: Wed, 04 Sep 2019 01:08:18 GMT
Max-Forwards: 70
Timestamp: 1567559298
CSeq: 3 REGISTER
Expires: 3600
Supported: path
Authorization: Digest username="425DIDNUM",realm="sipcarrier.com",uri="sip:sipcarrier.com:5060",response="0485b8548f4b8a472982546896f9b53e",nonce="9a97234eec80",cnonce="809ECA90",qop=auth,algorithm=MD5,nc=00000001
Content-Length: 0
SIP/2.0 200 OK
CSeq: 3 REGISTER
To: <sip:425DIDNUM@sipcarrier.com>;tag=sip+2+c6a9009a+5be26af0
Content-Length: 0
Expires: 3600
Contact: <sip:425DIDNUM@10.109.205.20:5060>;Expires=3600
Server: DC-SIP/2.0
OPTIONS sip:sipcarrier.com:5060 SIP/2.0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKC188E
To: <sip:sipcarrier.com>
Date: Wed, 04 Sep 2019 01:08:21 GMT
Call-ID: 524FEC5F-CDE711E9-B0EFC665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <sip:10.109.205.20:5060>
Content-Length: 0
SIP/2.0 200 OK
Call-ID: 524FEC5F-CDE711E9-B0EFC665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+1+c4d40080+1974fd4e
Content-Length: 0
Supported: resource-priority, siprec, 100rel
Server: DC-SIP/2.0
Allow-Events: message-summary, refer, dialog, line-seize, presence, call-info, as-feature-event, calling-name, ua-profile
Allow: INVITE, ACK, CANCEL, BYE, REGISTER, OPTIONS, PRACK, UPDATE, SUBSCRIBE, NOTIFY, REFER, INFO, PUBLISH
Accept-Encoding: identity
Accept: application/sdp, application/simple-message-summary, message/sipfrag, application/isup, application/x-simple-call-service-info, multipart/mixed, application/broadsoft, application/hook-flash, application/vq-rtcpxr, application/media_control+xml, application/dtmf-relay, text/plain, application/x-as-feature-event+xml, application/vnd.telekom.service_indication+xml, application/calling-name-info
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKD41A
Date: Wed, 04 Sep 2019 01:08:22 GMT
Call-ID: 52E8F7B1-CDE711E9-B0F0C665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
Thank you
Prabhu
Ok, thanks for clarification. Please share the debugs of a failed call when possible.
Please find the logs below.
Max-Forwards: 70
CSeq: 2 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
CSeq: 2 REGISTER
Content-Length: 0
Server: DC-SIP/2.0
Max-Forwards: 70
CSeq: 3 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
SIP/2.0 200 OK
CSeq: 3 REGISTER
Content-Length: 0
Expires: 3600
Server: DC-SIP/2.0
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
SIP/2.0 200 OK
CSeq: 101 OPTIONS
Content-Length: 0
Server: DC-SIP/2.0
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
SIP/2.0 200 OK
Call-ID: 52E8F7B1-CDE711E9-B0F0C665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+3+c7fa005f+39e6d046
Content-Length: 0
Server: DC-SIP/2.0
OPTIONS sip:425DIDNUM@10.109.205.20:5060 SIP/2.0
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+257675baf39be122139c6e5efc27b7431+sip+2+cdb657e
From: <sip:425DIDNUM@162.223.87.140>;tag=162.X.Y.235+2+95e835f1+585bcec8
Content-Length: 0
Contact: <sip:eba3d91eabb155f992ac478a7b902751@162.X.Y.235:5060>
Max-Forwards: 69
Call-ID: 0gQAAC8WAAACBAAALxYAAKEKx1btIe6HOPso+sSMSjrk335QQfW3RbAM1rrikAaA@162.X.Y.235
CSeq: 502093637 OPTIONS
Accept: application/sdp, application/dtmf-relay
SIP/2.0 200 OK
To: <sip:425DIDNUM@sipcarrier.com>;tag=71D10EBB-189A
Date: Wed, 04 Sep 2019 01:08:28 GMT
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 7417 1506 IN IP4 10.109.205.20
s=SIP Call
c=IN IP4 10.109.205.20
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+7e6e62a1f4557bc693ed90e727b083ee1+sip+3+cdcb77e
From: <sip:425DIDNUM@162.223.87.140>;tag=162.X.Y.235+3+1b36fcec+78a0d886
Content-Length: 0
Max-Forwards: 69
Call-ID: 0gQAAC8WAAACBAAALxYAAM/RITx/w5sMKHaFOd1/RedKzafKjwMDCrFI7SXzaLeV@162.X.Y.235
CSeq: 1035559698 OPTIONS
SIP/2.0 200 OK
To: <sip:425DIDNUM@sipcarrier.com>;tag=71D1844F-1A9F
Date: Wed, 04 Sep 2019 01:08:58 GMT
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 1152 2158 IN IP4 10.109.205.20
s=SIP Call
t=0 0
INVITE sip:425DIDNUM@10.109.205.20:5060 SIP/2.0
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+5ceb53914a0a9aed47588b4769016cb81+sip+1+ce9a230
From: "MY NAME" <sip:MY phone #@sipcarrier.com>;tag=162.X.Y.235+1+406ebbd6+44e1ece9
Expires: 180
Content-Length: 199
Call-Info: <sip:162.X.Y.235:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Supported: resource-priority,siprec, 100rel
Contact: <sip:e9e5e51db9188836b8852e52f7aa8849@162.X.Y.235:5060>
Call-ID: 0gQAAC8WAAACBAAALxYAAEQA5PNDkXejjvgwUzjPl9EJnrfVKPIMbJ6o6XcjghR4@162.X.Y.235
Max-Forwards: 67
v=0
o=- 94807448875850 94807448875850 IN IP4 162.X.Y.240
s=-
c=IN IP4 162.X.Y.240
t=0 0
m=audio 65484 RTP/AVP 0 18 101
a=rtpmap:101 telephone-event/8000
a=fmtp:18 annexb=no
a=ptime:20
SIP/2.0 100 Trying
Content-Length: 0
Content-Length: 0
ACK sip:425DIDNUM@10.109.205.20:5060 SIP/2.0
CSeq: 1028103836 ACK
Content-Length: 0
Max-Forwards: 67
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKE99F
Date: Wed, 04 Sep 2019 01:09:26 GMT
Call-ID: 795C4195-CDE711E9-B101C665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
SIP/2.0 200 OK
Call-ID: 795C4195-CDE711E9-B101C665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+1+c6fc0083+7f1abbc3
Content-Length: 0
Server: DC-SIP/2.0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKF102E
Date: Wed, 04 Sep 2019 01:09:27 GMT
Call-ID: 79F5E9A7-CDE711E9-B102C665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
SIP/2.0 200 OK
Call-ID: 79F5E9A7-CDE711E9-B102C665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+1+fb3a0085+2e9d0720
Content-Length: 0
Server: DC-SIP/2.0
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+421d0dca38adfa3f409a06c63fbf24391+sip+4+ceedf74
From: <sip:425DIDNUM@162.223.87.140>;tag=162.X.Y.235+4+686d66af+88c6c53a
Content-Length: 0
Max-Forwards: 69
Call-ID: 0gQAAC8WAAACBAAALxYAAP7uhVWOJR0ml8xmWGHR9IDJaukesOnL5WbAK5meGcTS@162.X.Y.235
CSeq: 631677641 OPTIONS
SIP/2.0 200 OK
To: <sip:425DIDNUM@sipcarrier.com>;tag=71D23507-1B9
Date: Wed, 04 Sep 2019 01:09:44 GMT
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 8614 6359 IN IP4 10.109.205.20
s=SIP Call
t=0 0
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+631b2db42d9d3663d87cb5b36248bb441+sip+1+ce9ab57
From: "MY NAME" <sip:MY phone #@sipcarrier.com>;tag=162.X.Y.235+1+fe08de3d+58c0246b
CSeq: 479324955 INVITE
Expires: 180
Content-Length: 201
Call-ID: 0gQAAC8WAAACBAAALxYAAMOT45Co9KNRfxEVVCy8bzvlklMkrar4RPp0AQHBxPK0@162.X.Y.235
Max-Forwards: 67
v=0
o=- 116458379064549 116458379064549 IN IP4 162.X.Y.240
s=-
t=0 0
m=audio 17098 RTP/AVP 0 18 101
a=fmtp:18 annexb=no
a=ptime:20
SIP/2.0 100 Trying
Date: Wed, 04 Sep 2019 01:10:03 GMT
Session-ID: 00000000000000000000000000000000;remote=afd108cb7b015b3f830e74186e84610a
Content-Length: 0
To: <sip:425DIDNUM@sipcarrier.com>;tag=71D28111-F1A
Content-Length: 0
CSeq: 479324955 ACK
Content-Length: 0
Max-Forwards: 67
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+678c1d9d51645d7ca6b8f7c3a5529cda1+sip+3+cdcc7fb
From: "MY NAME" <sip:MY phone #@sipcarrier.com>;tag=162.X.Y.235+3+baaf46b7+8224cf4
CSeq: 122707613 INVITE
Expires: 180
Content-Length: 199
Call-ID: 0gQAAC8WAAACBAAALxYAAGG5iw9xD7rAgYKHreAiMXBbZDdaGl/LH9T0Cfi22KTQ@162.X.Y.235
Max-Forwards: 67
v=0
o=- 74436419058646 74436419058646 IN IP4 162.X.Y.240
s=-
t=0 0
m=audio 17376 RTP/AVP 0 18 101
a=fmtp:18 annexb=no
a=ptime:20
SIP/2.0 100 Trying
Date: Wed, 04 Sep 2019 01:10:21 GMT
Session-ID: 00000000000000000000000000000000;remote=2167253e7c525d8c9498ae6b223ae752
Content-Length: 0
To: <sip:425DIDNUM@sipcarrier.com>;tag=71D2C803-1172
Content-Length: 0
CSeq: 122707613 ACK
Content-Length: 0
Max-Forwards: 67
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bK101C4C
Date: Wed, 04 Sep 2019 01:10:32 GMT
Call-ID: A06DA1FE-CDE711E9-B118C665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
SIP/2.0 200 OK
Call-ID: A06DA1FE-CDE711E9-B118C665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+2+e60b009d+cd242fbe
Content-Length: 0
Server: DC-SIP/2.0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bK11CB2
Date: Wed, 04 Sep 2019 01:10:33 GMT
Call-ID: A101A4B9-CDE711E9-B119C665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
SIP/2.0 200 OK
Call-ID: A101A4B9-CDE711E9-B119C665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+4+d2c40002+7603056e
Content-Length: 0
Server: DC-SIP/2.0
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+8e3dd78100ec288ab1bc9ddcbfea3f621+sip+2+d04e760
From: <sip:425DIDNUM@162.223.87.140>;tag=162.X.Y.235+2+61683efc+8a515997
Content-Length: 0
Max-Forwards: 69
Call-ID: 0gQAAC8WAAACBAAALxYAAAlUIYmckWLTsaUUhaC/S47cJf/u5mPS7rrm4eFaxYma@162.X.Y.235
CSeq: 441943681 OPTIONS
SIP/2.0 200 OK
To: <sip:425DIDNUM@sipcarrier.com>;tag=751E575E-100A
Date: Wed, 04 Sep 2019 16:31:45 GMT
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 6903 2631 IN IP4 10.109.205.20
s=SIP Call
t=0 0
CSeq: 42 REGISTER
From: <sip:425DIDNUM@sipcarrier.com>;tag=751E60A9-58B
To: <sip:425DIDNUM@sipcarrier.com>;tag=sip+2+d34d0090+9be4bd33
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKB9BEAD
Content-Length: 0
WWW-Authenticate: Digest realm="sipcarrier.com",nonce="9aee7efa4884",stale=false,algorithm=MD5,qop="auth"
Server: DC-SIP/2.0
SIP/2.0 200 OK
CSeq: 43 REGISTER
To: <sip:425DIDNUM@sipcarrier.com>;tag=sip+2+d34d0090+3a0cc0bc
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKB9C22D6
Content-Length: 0
Expires: 0
Server: DC-SIP/2.0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKB9D2117
To: <sip:2555@sipcarrier.com>
Date: Wed, 04 Sep 2019 16:31:59 GMT
Call-ID: 5A25AB8C-FFFFFFFFCE6811E9-FFFFFFFF9C90C665-411FD79F
Max-Forwards: 70
Timestamp: 1567614719
CSeq: 2 REGISTER
Contact: <sip:2555@10.109.205.20:5060>
Expires: 3600
Supported: path
Content-Length: 0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKB9E1250
To: <sip:7010@sipcarrier.com>
Call-ID: 5A2731EF-FFFFFFFFCE6811E9-FFFFFFFF9C91C665-411FD79F
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:7010@10.109.205.20:5060>
Expires: 3600
Supported: path
Content-Length: 0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKB9F212F
To: <sip:7050@sipcarrier.com>
Call-ID: 5A278003-FFFFFFFFCE6811E9-FFFFFFFF9C92C665-411FD79F
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:7050@10.109.205.20:5060>
Expires: 3600
Supported: path
Content-Length: 0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKBA02004
To: <sip:7060@sipcarrier.com>
Call-ID: 5A27A75A-FFFFFFFFCE6811E9-FFFFFFFF9C93C665-411FD79F
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:7060@10.109.205.20:5060>
Expires: 3600
Supported: path
Content-Length: 0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKBA12BE
From: <sip:425DIDNUM@sipcarrier.com>;tag=751E8FA1-961
Call-ID: 5A27CEB0-FFFFFFFFCE6811E9-FFFFFFFF9C94C665-411FD79F
Max-Forwards: 70
CSeq: 2 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
SIP/2.0 403 Forbidden
CSeq: 2 REGISTER
To: <sip:2555@sipcarrier.com>;tag=sip+2+c61900ac+1b1102ef
Content-Length: 0
Server: DC-SIP/2.0
CSeq: 2 REGISTER
To: <sip:7010@sipcarrier.com>;tag=sip+1+d38300a9+a8ac74d3
Content-Length: 0
Server: DC-SIP/2.0
CSeq: 2 REGISTER
To: <sip:7050@sipcarrier.com>;tag=sip+3+d0bf0033+6311c439
Content-Length: 0
Server: DC-SIP/2.0
CSeq: 2 REGISTER
To: <sip:7060@sipcarrier.com>;tag=sip+3+cf790034+8f1a90d3
Content-Length: 0
Server: DC-SIP/2.0
CSeq: 2 REGISTER
To: <sip:425DIDNUM@sipcarrier.com>;tag=sip+4+e52d00b1+35ea73e6
Content-Length: 0
WWW-Authenticate: Digest realm="sipcarrier.com",nonce="9aee845d4de7",stale=false,algorithm=MD5,qop="auth"
Server: DC-SIP/2.0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKBA21CC7
Max-Forwards: 70
CSeq: 3 REGISTER
Expires: 3600
Supported: path
Authorization: Digest username="425DIDNUM",realm="sipcarrier.com",uri="sip:sipcarrier.com:5060",response="fd92bc42afc3bd9b120709eaf6276916",nonce="9aee845d4de7",cnonce="869DA1CC",qop=auth,algorithm=MD5,nc=00000001
Content-Length: 0
SIP/2.0 200 OK
CSeq: 3 REGISTER
To: <sip:425DIDNUM@sipcarrier.com>;tag=sip+4+e52d00b1+b2defedc
Content-Length: 0
Expires: 3600
Server: DC-SIP/2.0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKBA3100B
Date: Wed, 04 Sep 2019 16:32:03 GMT
Call-ID: 5C355312-CE6811E9-9C95C665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKBA41172
Call-ID: 5C3615F8-CE6811E9-9C96C665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
SIP/2.0 200 OK
Call-ID: 5C355312-CE6811E9-9C95C665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+2+eab600b0+db0e8421
Content-Length: 0
Server: DC-SIP/2.0
SIP/2.0 200 OK
Call-ID: 5C3615F8-CE6811E9-9C96C665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+4+d5a000b5+8fcdd673
Content-Length: 0
Server: DC-SIP/2.0
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+0407421b7ab1566a9e3b26ede96c1ccc1+sip+3+d064824
From: <sip:425DIDNUM@162.223.87.140>;tag=162.X.Y.235+3+bc24b251+3108afb9
Content-Length: 0
Max-Forwards: 69
Call-ID: 0gQAAC8WAAACBAAALxYAAM9ruVWZKbFc42HcCPQtIc0SPSpCLyUXBWWLVSSmC1N8@162.X.Y.235
CSeq: 73082014 OPTIONS
SIP/2.0 200 OK
To: <sip:425DIDNUM@sipcarrier.com>;tag=751EC2AA-79A
Date: Wed, 04 Sep 2019 16:32:12 GMT
Content-Length: 171
v=0
o=CiscoSystemsSIP-GW-UserAgent 589 2806 IN IP4 10.109.205.20
s=SIP Call
t=0 0
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+8389d747440a4a50a03b32694daaa5e21+sip+3+d064fcb
From: <sip:425DIDNUM@162.223.87.140>;tag=162.X.Y.235+3+39f16c6e+71c28c45
Content-Length: 0
Max-Forwards: 69
Call-ID: 0gQAAC8WAAACBAAALxYAAOteYa1jmLjYkaUpsfwSKL0hYRm+3trFUVzUlyZSeQ1d@162.X.Y.235
CSeq: 732916599 OPTIONS
SIP/2.0 200 OK
To: <sip:425DIDNUM@sipcarrier.com>;tag=751F3837-124E
Date: Wed, 04 Sep 2019 16:32:42 GMT
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 3250 5420 IN IP4 10.109.205.20
s=SIP Call
t=0 0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKBA53CB
Date: Wed, 04 Sep 2019 16:33:08 GMT
Call-ID: 834096B5-CE6811E9-9CA1C665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKBA66A1
Call-ID: 83415A33-CE6811E9-9CA2C665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
SIP/2.0 200 OK
Call-ID: 834096B5-CE6811E9-9CA1C665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+2+ed0f00ba+9f772284
Content-Length: 0
Server: DC-SIP/2.0
SIP/2.0 200 OK
Call-ID: 83415A33-CE6811E9-9CA2C665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+2+e4c600ba+721125c6
Content-Length: 0
Server: DC-SIP/2.0
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+46ffafe07283eed19518bbc68424a8c51+sip+2+d04ff44
From: <sip:425DIDNUM@162.223.87.140>;tag=162.X.Y.235+2+248590a5+e7054f99
Content-Length: 0
Max-Forwards: 69
Call-ID: 0gQAAC8WAAACBAAALxYAAJa6NanYxd/j8qW7+q39Tjg3GIfKi+WMt+aXMzLq2uKe@162.X.Y.235
CSeq: 693091630 OPTIONS
SIP/2.0 200 OK
To: <sip:425DIDNUM@sipcarrier.com>;tag=751FADC5-24C2
Date: Wed, 04 Sep 2019 16:33:12 GMT
Content-Length: 171
v=0
o=CiscoSystemsSIP-GW-UserAgent 157 7389 IN IP4 10.109.205.20
s=SIP Call
t=0 0
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+0851027f4b3e5184f79bd039a717fe531+sip+2+d05062e
From: "KIRKLAND WA" <sip:my office #@sipcarrier.com>;tag=162.X.Y.235+2+1f3303b8+d332427f
CSeq: 208649570 INVITE
Expires: 180
Content-Length: 199
Contact: <sip:60b2c5cc0758944284d26a58a17966b1@162.X.Y.235:5060>
Call-ID: 0gQAAC8WAAACBAAALxYAAKymw/YgmtA84rPW4sGbJwvThuAWDaCqn5mEI7dasi53@162.X.Y.235
Max-Forwards: 16
v=0
o=- 11442189123347 11442189123347 IN IP4 162.X.Y.240
s=-
t=0 0
m=audio 53654 RTP/AVP 0 18 101
a=fmtp:18 annexb=no
a=ptime:20
SIP/2.0 100 Trying
Date: Wed, 04 Sep 2019 16:33:39 GMT
Session-ID: 00000000000000000000000000000000;remote=fd0a0788dcfb57c2b229f9296e4dc76c
Content-Length: 0
To: <sip:425DIDNUM@sipcarrier.com>;tag=75201759-CB2
Content-Length: 0
CSeq: 208649570 ACK
Content-Length: 0
Max-Forwards: 16
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+c75a7f000db35ae92defcde51ef8f3df1+sip+4+d185cda
From: "KIRKLAND WA" <sip:my office #@sipcarrier.com>;tag=162.X.Y.235+4+d91489cf+f20bc1bd
CSeq: 369459704 INVITE
Expires: 180
Content-Length: 201
Call-ID: 0gQAAC8WAAACBAAALxYAANl2HyCiNuMfO8p/1w4qZjaZJ1eiZOos0KFoD0qP/jp3@162.X.Y.235
Max-Forwards: 16
v=0
o=- 102959352268928 102959352268928 IN IP4 162.X.Y.240
s=-
t=0 0
m=audio 53754 RTP/AVP 0 18 101
a=fmtp:18 annexb=no
a=ptime:20
SIP/2.0 100 Trying
Date: Wed, 04 Sep 2019 16:33:42 GMT
Session-ID: 00000000000000000000000000000000;remote=03c3a66c8c1f5cb6a0ed54976e9321fe
Content-Length: 0
To: <sip:425DIDNUM@sipcarrier.com>;tag=752020C7-100A
Content-Length: 0
CSeq: 369459704 ACK
Content-Length: 0
Max-Forwards: 16
Via: SIP/2.0/UDP 162.X.Y.235:5060;branch=z9hG4bK+8037b745d2bf2b61d91b9841107257dd1+sip+1+d134663
From: <sip:425DIDNUM@162.223.87.140>;tag=162.X.Y.235+1+2b753663+7aa6eb07
Content-Length: 0
Max-Forwards: 69
Call-ID: 0gQAAC8WAAACBAAALxYAAPyJ/1MDX2WjdQNrYmCCPEHGnEBEPtFphP6WPmGxDXNn@162.X.Y.235
CSeq: 1011503545 OPTIONS
SIP/2.0 200 OK
To: <sip:425DIDNUM@sipcarrier.com>;tag=75209653-13DF
Date: Wed, 04 Sep 2019 16:34:12 GMT
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 3724 1978 IN IP4 10.109.205.20
s=SIP Call
t=0 0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKBA7243A
Date: Wed, 04 Sep 2019 16:34:14 GMT
Call-ID: AA4BDCF6-CE6811E9-9CBFC665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
Via: SIP/2.0/UDP 10.109.205.20:5060;branch=z9hG4bKBA8F34
Call-ID: AA4CA074-CE6811E9-9CC0C665-411FD79F@10.109.205.20
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
SIP/2.0 200 OK
Call-ID: AA4BDCF6-CE6811E9-9CBFC665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+1+efeb001b+dacf3a9
Content-Length: 0
Server: DC-SIP/2.0
SIP/2.0 200 OK
Call-ID: AA4CA074-CE6811E9-9CC0C665-411FD79F@10.109.205.20:5060
CSeq: 101 OPTIONS
To: <sip:sipcarrier.com>;tag=sip+3+e942006f+9067c4b3
Content-Length: 0
Server: DC-SIP/2.0
I was able to get this working by removing the outbound proxy command from my incoming dial peer and now I see incoming calls but my outgoing is still an issue.
Below is the outgoing dial peer, any suggestions. I get same 503 service unavailable error
preference 2
media monitoring
session target dns:SIP.com
voice-class codec 1
voice-class sip outbound-proxy dns:SIP.com
dtmf-relay rtp-nte
no vad
authentication username 123456789 password 7 password realm SIP.com
Thank you
What is the configuration of your GigabitEthernet0/0/0?
Thank you Rodrigo. below is the port config. That's connecting to core switch which connects to WAN edge router.
description CTS to Core Switch 4/0/44
ip address 10.109.205.20 255.255.255.192
negotiation auto
Thank you
Looks fine. Can you run both debug ccapi inout and a debug ccsip messages and share the log of a test call? And can you do the same with an outbound call?
