03-27-2015 10:07 AM - edited 03-17-2019 02:28 AM
Hi all,
Could someone confirm if i'm right or not on hardware requirments of a Cisco 3745-V-CCME
I think it consist of
Cisco3745
cme 7.1.0
NM-HD-2VE
Many thanks
Billy
Solved! Go to Solution.
03-30-2015 01:07 AM
Hi Billy,
First of all you may be aware of this but I will state just to be sure all of these parts are End of Life. I am assuming you are looking at buying these for your lab or buying second hand for any reason.
Regarding the requirements you can run CME on 3745. Version of CME is tied to the IOS you will run on the router. Refer to below guide for CME and IOS version match and chose accordingly:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
Lastly your NM-HD-2VE should provide you PVDM resources.
In addition if you need E1 or FXO lines you will need the appropriate card for terminating those lines.
Additionally if you need voice mail functionality, you will need to buy a CUE module as well.
-Terry
Please rate all helpful posts
03-30-2015 02:07 AM
No probs mate - glad that helped.
If you IOS is 12.4(9) you will have CME version 4. As said before CME version is directly tied to the IOS version. Please see from the link I posted above which CME version is tied to which IOS:
Cisco IOS Release 1 | Cisco Unified CME Version | Cisco Unified CME GUI Version 2 | Version Specification Link 3 |
T-Train | S-Train | — | — | — |
15.4(3)M | 15.4(3)S | 10.5 | 10.5.0.0 | |||||||||||
15.3(3)M | — | 10.0 - Recommended Version | 10.0.0 | |||||||||||
15.3(2)T | — | 9.5 | 9.5.0.0 | |||||||||||
15.2(4)M | — | 9.1 | 9.1.0.0 |
15.2(2)T | — | 9.0 | 9.0.0.0 |
15.2(1)T | — | 8.8 | 8.8.0.0 |
15.1(4)M | — | 8.6 | 8.6.0.0 |
15.1(3)T and VG350 | — | 8.5 | 8.5.0.0 |
15.1(2)T | — | 8.1 | 8.1.0.0 |
15.1(1)T | — | 8.0 | 8.0.0.0 |
15.0(1)XA and VG350 | — | 8.0 | 8.0.0.0 |
15.0(1)M9 | — | 7.1 | 7.1.1.0 |
12.4(24)T | — | 7.1 | 7.1.1.0 |
12.4(22)YB | — | 7.1 | 7.1.0.0 |
12.4(22)T | — | 7.0(1) | 7.0.0.1 |
12.4(20)T1 | — | 7.0 | 7.0.0.1 |
12.4(20)T | — | 7.0 | 7.0.0.0 |
12.4(15)XZ | — | 4.3 | 4.3.0.0 |
12.4(11)XW9 | — | 4.2 | 4.2.0.4 |
12.4(15)T7 8 | — | 4.1 | 4.1.0.2 |
12.4(15)T 5, 7 | — | 4.1 | 4.1.0.2 |
12.4(11)XJ | — | 4.1 | 4.0.3.0 |
12.4(11)T 5 | — | 4.0(2) | 4.0.3.1.a |
12.4(4)XC4 | — | 4.0(3) | 4.0.3.0 |
12.4(9)T 4, 6 | — | 4.0(0) | 4.0.0.1 |
-Terry
03-30-2015 01:07 AM
Hi Billy,
-Terry
03-30-2015 01:56 AM
Many Thanks Terry,
My IOS is c3745-ipvoicek9-mz.124-9.T.bin i think that will be ok
03-30-2015 02:07 AM
-Terry
03-30-2015 02:59 AM
Doh thanks again :)
03-30-2015 03:02 AM
No Worries, See you around.
-Terry
03-31-2015 07:41 PM
03-31-2015 10:53 PM
Thanks for the appreciation Marcelo my friend.
-Terry
