cisco 3825 and vic-4fxs no voice port
malakipaa
Good day experts. I have a bit of dillema. I got the hw in subject installed together but can't see the 4 voice ports in IOS. I have research everywhere and can't get a clear answer. The only sort of guess I'm getting is because I don't have any pvdm installed in the router. Can somebody help me? Thanks.
2 Accepted Solutions
You need to have PVDMs  installed .
regds,
aman
Yes - you need PVDMs. All Cisco VOIP cards need PVDMs.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
8 Replies 8
George Thomas
Level 10
Level 10
What does show diag and show inventory give you?
Please rate useful posts.
Hi George,
It's
R2#show inventory
NAME: "3825 chassis", DESCR: "3825 chassis"
PID: CISCO3825         , VID: V03 , SN: FHK1045F0EM
NAME: "Four port FXS DID voice interface daughtercard on Slot 0 SubSlot 0", DESC
R: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID=     , VID: 3.1, SN: JAE083202F9
R2#
regds,
aman
Hi Aman,
Are you %100?
Yes...
can u share show runn?
regds,
aman
Aaron
Thank you all!
Then show voice port
R2#show voice port
EFXS 50/0/1 Slot is 50, Sub-unit is 0, Port is 1
 Type of VoicePort is EFXS
 Operation State is UP
 Administrative State is UP
 No Interface Down Failure
 Description is not set
 Noise Regeneration is enabled
 Non Linear Processing is enabled
 Non Linear Mute is disabled
 Non Linear Threshold is -21 dB
 Music On Hold Threshold is Set to -38 dBm
 In Gain is Set to 0 dB
 Out Attenuation is Set to 0 dB
 Echo Cancellation is enabled
 Echo Cancellation NLP mute is disabled
 Echo Cancellation NLP threshold is -21 dB
 Echo Cancel Coverage is set to 8 ms
 Echo Cancel worst case ERL is set to 6 dB
 Playout-delay Mode is set to adaptive
 Playout-delay Nominal is set to 60 ms
 Playout-delay Maximum is set to 1000 ms
 Playout-delay Minimum mode is set to default, value 40 ms
 Playout-delay Fax is set to 300 ms
 Connection Mode is normal
 Connection Number is not set
 Initial Time Out is set to 15 s
 Interdigit Time Out is set to 5 s
 Call Disconnect Time Out is set to 60 s
 Ringing Time Out is set to 180 s
 Wait Release Time Out is set to 30 s
 Companding Type is u-law
 Region Tone is set for US
 Station name Sarah, Station number 9055645636
 Caller ID Info Follows:
 Standard BELLCORE
 Translation profile (Incoming):
 Translation profile (Outgoing):
 Digit Duration Timing is set to 100 ms
EFXS 50/0/2 Slot is 50, Sub-unit is 0, Port is 2
 Station name Erik, Station number 2
 Standard BELLCORE
R2#
