ā05-18-2013 11:41 PM - edited ā03-16-2019 05:23 PM
We have a 3845 and we want to add a "VWIC2-2MFT-T1/E1", and we install it in slot 0 as shown in bold in the show diag below.
sh diag
3845 Backplane EEPROM:
Hardware Revision : 1.0
Top Assy. Part Number : 800-23093-01
Board Revision : B0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC1050083U
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Part Number : 73-8639-04
CLEI Code : IPME110BRA
Chassis Serial Number : FHK1101U058
Product (FRU) Number : CISCO3845
Version Identifier : V01
Hardware date code : 20061212
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 04 2B 41 01 00 C0 46 03 20 00 5A 35 01
0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 30 35 30 30 38 33 55 03 00 81 00 00 00 00 04 00
0x30: 82 49 21 BF 04 C6 8A 49 50 4D 45 31 31 30 42 52
0x40: 41 C2 8B 46 48 4B 31 31 30 31 55 30 35 38 CB 92
0x50: 43 49 53 43 4F 33 38 34 35 20 20 20 20 20 20 20
0x60: 20 20 89 56 30 31 20 83 01 32 1C 1C FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Backplane Registers
Backplane Revision: 00BE
Power Supply Status: 090F
-48V PS and Env Status: FFFF
-48V Isolation Control: 0007
Backplane Cookie: 000C
ENM/Backplane FPGA Revision: 00BE
ENM/Backplane FPGA Int0 Status: FFFF
ENM/Backplane FPGA Int2 Status: 00FF
ENM/Backplane FPGA Int4 Status : EF00
ENM Interrupt Mask: 0057
ENM/BP FPGA Interrupt 4 Mask: 0040
ENM1 Test Port: 00E3
ENM2 Test Port: 00E3
ENM3 Test Port: 00E3
ENM3 Test Port: 00C3
ENM LED Control: 0077
ENM OIR Control: 0000
ENM OIR Status: 2292
ENM PCI Speed Status 000D
Backplane FPGA Diag Int Control: FFFF
ENM1 OIR State Machine Status: C4C4
ENM2 OIR State Machine Status: C441
ENM3 OIR State Machine Status: 0000
ENM4 OIR State Machine Status: 0000
Backplane Voltage Margin: 0000
Slot 0:
C3845 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapter, 15 ports
Port adapter is analyzed
Port adapter insertion time unknown
Onboard VPN : FW ver01100200
EEPROM contents at hardware discovery:
PCB Serial Number : FOC10520T32
Hardware Revision : 1.3
Top Assy. Part Number : 800-23616-05
Board Revision : A0
Deviation Number : 86930
Fab Version : 05
RMA History : 00
Processor type : 69
Product (FRU) Number : CISCO3845-MB
Version Identifier : V05
Chassis MAC Address : 001a.a206.de10
MAC Address block size : 48
Part Number : 73-8799-08
Hardware date code : 20070101
0x00: 04 FF C1 8B 46 4F 43 31 30 35 32 30 54 33 32 40
0x10: 04 2C 41 01 03 C0 46 03 20 00 5C 40 05 42 41 30
0x20: 88 00 01 53 92 02 05 03 00 81 00 00 00 00 04 00
0x30: 09 69 C6 8A 49 50 4D 45 31 31 30 42 52 41 CB 8C
0x40: 43 49 53 43 4F 33 38 34 35 2D 4D 42 89 56 30 35
0x50: 20 D9 02 40 C1 C3 06 00 1A A2 06 DE 10 43 00 30
0x60: 82 49 22 5F 08 83 01 32 3E D5 C2 8B 46 48 4B 31
0x70: 31 30 31 55 30 35 38 FF FF FF FF FF FF FF FF FF
PVDM Slot 0:
64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8541-05
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC10501E4G
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-64
0x00: 04 FF 40 03 EC 41 04 00 82 49 21 5D 05 42 41 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 35 30
0x20: 31 45 34 47 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 36 34 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
2nd generation - FXO Voice daughter card (4 port)
Hardware Revision : 5.0
Top Assy. Part Number : 800-21589-02
Board Revision : A0
Deviation Number : 0-0
Fab Version : 04
PCB Serial Number : FOC10501BRJ
RMA History : 00
Product (FRU) Number : VIC2-4FXO
CLEI Code : CNUIAPRAAA
0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 02
0x10: 42 41 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 30 35 30 31 42 52 4A 03 00 81 00 00 00 00 04 00
0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 31 20
0x40: C6 8A 43 4E 55 49 41 50 52 41 41 41 FF FF FF FF
WIC Slot 1:
Top Assy. Part Number : 800-21589-04
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC11456CSK
RMA History : 00
Version Identifier : V03
CLEI Code : CNUIAXJAAB
0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 04
0x20: 31 34 35 36 43 53 4B 03 00 81 00 00 00 00 04 00
0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 33 20
0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 42 FF FF FF FF
WIC Slot 3:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : E0
Fab Version : 04
PCB Serial Number : FOC15296B2F
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
0x10: 42 45 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 35 32 39 36 42 32 46 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
Slot 1:
NM-2CE1T1_PRI Port adapter, 2 ports
Top Assy. Part Number : 800-21551-02
Board Revision : A0
Fab Version : 03
PCB Serial Number : FOC10503TT0
RMA History : 00
Fab Part Number : 28-5935-03
Manufacturing Test Data : 00 00 00 00 00 00 00 00
Field Diagnostics Data : 00 00 00 00 00 00 00 00
Product (FRU) Number : NM-2CE1T1-PRI
0x00: 04 FF 40 03 9E 41 01 00 C0 46 03 20 00 54 2F 02
0x10: 42 41 30 80 00 00 00 00 02 03 C1 8B 46 4F 43 31
0x20: 30 35 30 33 54 54 30 03 00 81 00 00 00 00 04 00
0x30: 85 1C 17 2F 03 C4 08 00 00 00 00 00 00 00 00 C5
0x40: 08 00 00 00 00 00 00 00 00 CB 8D 4E 4D 2D 32 43
0x50: 45 31 54 31 2D 50 52 49 89 56 30 31 20 FF FF FF
Slot 2:
High Density Voice NM-HDV2-2T1/E1 Port adapter
Hardware Revision : 1.1
Top Assy. Part Number : 800-22168-03
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC105147KD
RMA History : 00
Fab Part Number : 28-6126-04
Product (FRU) Number : NM-HDV2-2T1/E1
0x00: 04 FF 40 03 DB 41 01 01 C0 46 03 20 00 56 98 03
0x10: 42 41 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 30 35 31 34 37 4B 44 03 00 81 00 00 00 00 04 00
0x30: 85 1C 17 EE 04 C4 08 00 00 00 00 00 00 00 00 C5
0x40: 08 00 00 00 00 00 00 00 00 CB 8E 4E 4D 2D 48 44
0x50: 56 32 2D 32 54 31 2F 45 31 89 56 30 33 20 D9 02
0x60: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FPGA revision:0x16C
WIC Slot 1:
HDV2 on board t1/e1 controller (2 port)
PVDM Slot 0:
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC10501DCH
RMA History : 00
Processor type : 00
0x20: 31 44 43 48 03 00 81 00 00 00 00 04 00 09 00 CB
Slot 3:
Board Revision : B0
Fab Version : 03
PCB Serial Number : FOC121333PS
RMA History : 00
0x10: 42 42 30 80 00 00 00 00 02 03 C1 8B 46 4F 43 31
0x20: 32 31 33 33 33 50 53 03 00 81 00 00 00 00 04 00
AIM Module in slot: 0
PCB Serial Number : FOC10474AQ9
Top Assy. Part Number : 800-24800-02
Board Revision : A0
Fab Version : 03
RMA History : 00
CLEI Code : CNUIAM0AAA
Product (FRU) Number : AIM-VPN/HPII-PLUS
0x00: 04 FF C1 8B 46 4F 43 31 30 34 37 34 41 51 39 40
0x10: 01 4D 41 01 01 C0 46 03 20 00 60 E0 02 42 41 30
0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
0x30: C6 8A 43 4E 55 49 41 4D 30 41 41 41 CB 91 41 49
0x40: 4D 2D 56 50 4E 2F 48 50 49 49 2D 50 4C 55 53 89
0x50: 56 30 31 20 FF FF FF FF FF FF FF FF FF FF FF FF
And after we specify the card type as below:
card type e1 0 3
But the problem is when want to configure the "network-clock-participate" for this controller it show the following message:
network-clock-participate wic 0
WIC slot is empty or does not support clock participate
And if i want to configure the "network-clock-participate" from the slot it like below:
network-clock-participate slot ?
<1-4> Slot Number
and when try to ignore this message and create the "pri-group timeslots" it show like below:
pri-group timeslots 1-31 service mgcp
%Configure network-clock-participate wic <slot> first
i think the slot 0 in the 3845 router is not support for this card "VWIC2-2MFT-T1/E1", can anyone confirm this, or provide me with the solution.
ā05-19-2013 12:15 AM
Hi Mohammed,
VWIC2-2MFT-T1/E1 is card supported on 3845 router .
In case, if it was not supported , then message in show diag would have shown as Port Adaptor UNKNOWN.
The error message which u are gtting while configuring network clock partiticpiate is becuase if FXO card card inserted in slot 0 .Either u insert VWIC2 card in slot 0 and configure the command network-clock-participate wic 0 or other way is to configure network-clockpartiticpate wic 3.
regds,
aman
ā05-19-2013 02:10 AM
Hi aman,
the router has a E1 installed on slot three up and running, and we have "network-clock-participate slot 2" in the configuration, so if i add "network-clockpartiticpate wic 3" command will solve the problem and let the controoler to get it clock from wic 3? and does it affect the running interfaces?
ā05-19-2013 02:16 AM
HI Mohammed,
In this case, u need to configure network-clock-select to assign the priority.
You can also refer the doc
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008031a072.shtml
regds,
aman
ā05-19-2013 03:14 AM
the router in now configured with :
sh runn | i network-clock-
no network-clock-participate wic 3
network-clock-select 1 E1 2/0
and after i read the document, what happned if i add the following commands:
network-clock-select 2 E1 3/0
does this affect the running controllers?does this solve my problem?
ā05-19-2013 04:13 AM
Hi Mohammed,
when u enter the commands network-clock-participate slot 2 and 3 respectively, then u need to enter network-clock -select as well by assigning the priority 1 and 2 . In case of failure of link terminated on 2 , link terminated on 3 would be used as clock source.
When u enter the commands, the running controllers would take the clock from first priority source.Do it in maintenance window for 10 minutes.
You can run show netowrk-clocks to check the clocking source.
or just make one clock souce.
regds,
aman
ā05-19-2013 01:49 AM
Card is in slot 3, not 0.
ā05-19-2013 02:11 AM
those e1 conftrollers is :
conftroller e1 0/3/0
conftroller e1 0/3/1
