â05-27-2013 04:14 AM - edited â03-16-2019 05:31 PM
Hi all!
Information:
I have CUCM 8.6.2.20000-2 and many Cisco IP Phone 3905 (SIP). Some of them deployed in central office and some in remote sites.
Phone information:
Boot Version: 3905.0-0-0-01-01
DSP Version: 12.0.0.8
Application: 3905.9-2-2-0
Symptoms:
In remote sites only!
The phone is registered and working fine. However, after few hours idle state I lift the handset, dial any number and nothing happens. Drop the call and try again 2-3 times. After that either call passed or get permanent busy tone (need to reboot the phone to work again).
The phone is marked as registered on CUCM and I hear dial tone when lifted the handset.
I cannot collect debug messages from phones, because as soon as I login via telnet it going work fine.
There is no such problem in central office.
Phones print following messages in terminal all the time:
17:07:10:302 x [CENTRAL] CDP/LLDP-MED CB function is called
17:07:26:491 [sip] 03:58:24.490 pjsua_acc.c SIP outbound status for acc 0 is not active
17:07:26:495 [sip] 03:58:24.494 pjsua_acc.c "п°пâŠŃâĐżâĐżâŠĐżâ© Đż ŃâĐżĐŃâĐżâȘĐżâŠĐżÒ"<sip:7102@192.168.13.50:5060>: registration success, status=200 (OK ), will re-register in 120 seconds
17:07:26:502 [sip] 03:58:24.500 pjcu.c pjcu_on_reg_state2(), Account["п°пâŠŃâĐżâĐżâŠĐżâ© Đż ŃâĐżĐŃâĐżâȘĐżâŠĐżÒ"<sip:7102@192.168.13.50:5060>] : OK, status=200
17:07:26:506 x [pcu] pcuRcvHandler(CALL), SRV_EV, eid=0, cid=65535,
17:07:26:510 x [pcu] [pcux_insrv_cb():7071] CUCM_DateTime:Mon, 27 May 2013 11:07:26 GMT
17:07:26:511 x [pcu] Sync time from server: Mon, 27 May 2013 11:07:26 GMT
17:07:26:515 x [pcu] [set_svr_type][1599] Bfe active_server_idx=0, serverType=0
17:07:26:515 x [pcu] [set_svr_type][1602] Aft serverType=0, Server Number=2
17:07:26:531 [ipps] ----- PCU: CC_SRV, pid=0, eid=0, cid=65535 -----
17:07:26:532 [ipps] In func: remoteNtyEvtProcess(), lib = 0, cid = 65535, ntyEv = 0
17:07:26:533 f [ipps] In func: remoteNtyEvtProcess(), recv inservice nty, svrType = 0, cause = 0
17:07:26:534 f [MMI] <RCV>: In func: ui_nty(), lid = 0, cid = 65535, ntyEv = 0
17:07:26:535 x [CENTRAL] IPPS CB function(RegStatus) is called (1) with Line (0)
17:07:26:536 f [ipps] In func: mlcu_isKpmlEnabled(), KPML value = 3, blRet = 1
17:07:26:537 x [CENTRAL] Enter FSM: State(STANDBY) | Event(REGISTER_OK) | Cause(0)
17:07:26:540 x [CENTRAL] Unexpected event REGISTER_OK (cause=0) at STANDBY state
17:07:26:541 x [CENTRAL] Waiting event in STANDBY
17:07:58:990 x [CENTRAL] CDP/LLDP-MED CB function is called
17:08:39:022 [sip] 03:59:37.021 pjcu.c pjcuRcvHandler(KA), KA_REQUEST, eid=-1, p1=192.168.70.1:5060
17:08:39:040 [sip] 03:59:37.036 pjcu.c pjcu_rpt_ka_status(), target(192.168.70.1:5060): status=1, id=27
17:08:39:044 x [pcu] pcuRcvHandler(KA), KA_RESPONSE, eid=0, addr=192.168.70.1:5060, status=1
17:08:39:050 x [pcu] [pcu_polling_sipserver_thread():1478] mark!
17:08:54:130 x [CENTRAL] CDP/LLDP-MED CB function is called
Thanks for your help.
Solved! Go to Solution.
â01-07-2014 11:44 AM
Please try to upgrade to the latest available firmware, 9.4(1), and try again.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
â05-27-2013 05:43 AM
Hi Anton,
Have you try upgrading the phone firmware?
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas Ăștiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
â05-27-2013 05:58 AM
Hi!
Upgraded to the latest firmware.
â05-27-2013 06:04 AM
Have you try running a softphone (CIPC) instead of 3905? Try this to see if the problem is the phone or CME.
â05-27-2013 06:23 AM
I have tried Cisco IP Communicator and other models of cisco ip phones (like 7911 and 7945). They are working perfectly well. Also, there is no problem with third-party SIP devices, tested CSipSimple softphone on android. The problem is only with 3905 phones.
â05-27-2013 06:31 AM
Try Downgrating the phone to another firmware version.
â05-27-2013 08:43 PM
There are 2 versions of firmware on cisco.com. cmterm-3905.9-2-1-0 is the default firmware going with CUCM 8.6.2.20000-2 for 3905 phones and cmterm-3905.9-2-2-0 I've installed recently. Both versions of firmware with same problems.
Some new information. I get traffic dump with wireshark.
INVITE sip:7@192.168.13.50:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 192.168.70.86:3457;rport;branch=z9hG4bKPjdp3HjFLs7Dy03RL9ce.16qung.tOq5O3
Max-Forwards: 70
From: "............ .............." <7102>;tag=5a25b465-747b-4c31-a020-1a96368274277102>
To: sip:7@192.168.13.50
Contact: <42C2685B-4526-F89D-C009-8B283FCF69A5>;+sip.instance="
Call-ID: e9edcc43-6a9b-42b8-8efc-99f702b313d1
CSeq: 28324 INVITE
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
User-Agent: Cisco-CP3905/9.2.1
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-monrec,X-cisco-config,X-cisco-sis-4.0.0,X-cisco-xsi-7.0.1
Expires: 900
Accept: application/sdp
Allow-Events: kpml,dialog
Remote-Party-ID: "............ .............."<7102>;privacy=off7102>
Content-Type: application/sdp
Content-Length: 294
As you can see phone trying to invite 7@192.168.13.50:5060, BUT I dial 7103 DN from 7102. So where are other numbers? Bug?
â08-29-2013 08:11 AM
Hi Anton Proskuryakov,
Have you found a solution for this problem or not?
â10-03-2013 02:39 AM
I have same problem here. 3905.9-2-2T14 is the 3905 version and
8.6.2.22900-9 is the CUCM version.
â10-03-2013 04:48 AM
I haven't found a solution yet.
â10-03-2013 06:41 AM
what about cucm patches? or tac case?
â10-24-2013 01:22 PM
Hi, i have the same problem. Did you find a soluction to fix it?
â10-24-2013 10:37 PM
what is your cucm version?
â10-25-2013 05:19 AM
hi, i've just opened a tac case. I'll tell you if i find a fix.
Full CUCM version: 8.6.2.23900-10
Number of servers on your cluster: 3
Firmware on the affected phone: 9.2.2.ES6
â01-07-2014 08:45 AM
Hi, f.rowan
Did you find a solution for this bug?
I have the same problem on CUCME 10.0 and 9.1 versions. I tried all phone firmware versions, but unsuccessfully.
I will be very grateful if you write the fix. Thanks in advance.
