ā08-02-2015 03:33 AM - edited ā03-17-2019 03:50 AM
dear ,
i face one issue when i finish from install the CME , all device working but nor 3905 send only one digit regarding the Debug
after i make tftp-path command line i get this error :
%Error deleting system:/cme/sipphone/SIPDefault.cnf (Invalid argument)
%Error deleting system:/cme/sipphone/syncinfo.xml (Invalid argument)
%Error deleting system:/cme/sipphone/softkeyDefault.xml (Invalid argument)
%Error deleting system:/cme/sipphone/softkeyDefault_kpml.xml (Invalid argument)
%Error deleting system:/cme/sipphone/featurePolicyDefault.xml (Invalid argument)
%Error deleting system:/cme/sipphone/SEP346288DB911C.cnf.xml (Invalid argument)
%Error deleting system:/cme/sipphone/SEP346288DA5312.cnf.xml (Invalid argument)
%Error deleting flash:/its/SIPDefault.cnf (File not found)
%Error deleting flash:/its/syncinfo.xml (File not found)
%Error deleting flash:/its/softkeyDefault.xml (File not found)
%Error deleting flash:/its/softkeyDefault_kpml.xml (File not found)
%Error deleting flash:/its/featurePolicyDefault.xml (File not found)
%Error deleting flash:/its/SEP346288DB911C.cnf.xml (File not found)
%Error deleting flash:/its/SEP346288DA5312.cnf.xml (File not found)
this is my configuration
vvoice register global
mode cme
source-address 66.4.65.1 port 5060
timeouts interdigit 2
max-dn 75
max-pool 80
load 6961 SIP69xx.9-4-1-3
load 6921 SIP69xx.9-4-1-3
load 3905 CP3905.9-2-1-0
load 8831 sip8831.9-3-3-5
authenticate register
authenticate realm cisco.com
timezone 31
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile sync 0001432161937296
date-format D/M/Y
voice register dn 6
number 2101
pickup-group 10
voice register pool 6
id mac 3462.88DB.911C
type 3905
number 1 dn 6
cor incoming STAFF default
dtmf-relay sip-kpml
voice-class codec 1
username u2101 password cisco
no vad
voice register dn 45
number 2907
pickup-group 10
voice register pool 45
id mac 3462.88DA.5312
type 3905
number 1 dn 45
dtmf-relay sip-kpml
voice-class codec 1
username u2907 password cisco
no vad
please help me to fixed this issue
thanks
ā08-13-2015 02:50 PM
This discussion has been reposted from SBCS - UC500 to the IP Telephony community.
