Cisco 4000 FXS SIP REC
bo liu
Level 4
Level 4
I know that the Cisco 4000 ISR can be configured as a CUBE to support SIP REC recording.
My question is whether I can also use SIP REC for recording if I install 72-port FXS on this ISR?
Whether CUBE will also send the audio of the analog interface to the recording server?
Jonathan Schulenberg
So long as you attach the SIPREC config to the VOIP dial-peer I wouldn’t expect it to matter what the other side is: IP, TDM, or analog. Full disclaimer that I haven’t tested it.
