Walkthrough Wednesdays
141
cesar.fiestas
Beginner
Cisco 4000 series Voice compatibility and SIP
I hope everyone is doing great. I am planning to deploy a Cisco 4351 with SIP to the PSTN although the Call Manager Cluster that I will using is at 8.5 version,Now I am almost positive that the Cisco 4k series will not work with cucm 8.5 using MGCP BUT since I will not be using MGCP, is there any known compatibility issues IF i configure the cisco 4351 with a sip trunk on the UCM side as well as to the ITSP side?.
Cesar Fiestas
2 REPLIES 2
Manish Gogna
Hi Cesar,
I don't see any limitations if you use it as a CUBE with cucm 8.5, however you need cucm 9.1.2 or above to use its DSP's for Conferencing, transcoding,MTP, and RFC 2833 as per the last row of Table 7 of the following link
http://www.cisco.com/c/en/us/products/collateral/unified-communications/tdm-gateways/data-sheet-c78-729824.html
Manish
Thanks Manish for the info. I appreciate your time.
-Cesar Fiestas
Content for Community-Ad
Spotlight Awards 2021
