Highlighted
Beginner
cisco 6921 no miss call records
on display it say 2 miss call and when I press softkey detail it say no miss call. Also when I go to calls, received and placed calls are list but miss are not recorded.
I update phone  firmware to latest wersion but still same!
cmterm-69xx-sip.9-3-1-5.cop.sgn
CCM 7.1.5
THX
Ivan
19 REPLIES 19
Participant
Hi Ivan,
Could you please check if TFTP server configured on the phone. Or phone learning about TFTP.
If not you may be missing option 150.
Please do rate if the given information helps
Beginner
Hi Amrinder,
thx you for your replay. Option 150 was configured, tftp is restarted but still no same issue.
On other cisco phones 7941, 7911 works ok.
regards,
Ivan
Participant
Hi Ivan,
could you please try to factory reset one of the phone and configure it again.
lets see if it record any miss call.
thanks
Hi Ivan,
It seems that you are being affected by the following BUG: CSCua86581
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCua86581
Though it mentions CUCM 8, it seems, that it has more to do with phone firmware.
There is an ES Patch available,so, if you open a TAc case, The Engineer should be able to provide you the same.
Som.
Participant
Hi Ivan,
Just another thing to check
if you log to ur call manager and find that extension .
Under the line, there will be a tick box “Log miss call"
Please check if that ticked.
thanks
Beginner
thx everyone for help and replay. I am on short vacation and I am not on-line so sorry for not replaying.
Amrinderi I cant find that option?!?
THX
Ivan
Beginner
I download 9.2(4) firmware, upload it to tffp server, restart it, check on device-device settings -
Device Defaults Configuration is selected SCCP69xx.9-2-4-3, restart the phone but phone is not downgrading?
What did I miss? do I need to press any key?
THX,
Ivan
Collaborator
Restart the TFTP Service.
Beginner
i restart TFTP two times.... but nothing...
Beginner
LRO = Large Receive Offload? Switch Setting and is enabled upon defaullt fixed in 4.1 pack 2.
Beginner
Ethtool -k eth0 LRO= No
Beginner
it upgrade from 9.0 to 9.3 with no problem, so I think is no problem with LRO. but i will check that option tomorrow on job...
Hall of Fame Community Legend
Hi Ivan,
Just to verify that you used the "signed" files - as the phones will not downgrade
otherwise
cmterm-69xx-sccp.9-2-4-3.cop.sgn
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
Beginner
Content for Community-Ad
July's Community Spotlight Awards
