Cisco 6941 Firmware upgrade to 9-4-1-3SR3 in CUCM 8.6.2 Time Synchronization Issue
Andrade_Narcis
Recently upgraded 6941 ip phones for a client from SCCP69xx.9-2-1-0 to SCCP69xx.9-4-1-3SR3. The  time is now several hours ahead. No changes have been made to CUCM or NTP Servers. Has anyone ever experienced and taken steps to fix this issue.
Ratheesh Kumar
Hi there
Can you check your CUCM NTP Status. If your NTP associations are good. then most likely its a firmware issue. Whats the behavior if you use a different firmware.
I found a similar issue with a community member with CME and the same firmware for time mismatch. no solutions though
https://supportforums.cisco.com/t5/ip-telephony/cme-ip-phone-time-mismatch/td-p/3378819
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Hi Kumar,
The NTP Associations seem to be fine, the firmware utilized before upgrade was SCCP69xx.9-2-1-0, didn't have any problem with time synchronization. Only when firmware was upgraded this issue occurred.
If the time mismatch was triggered after the firmware upgrade then sounds like a bug. Go ahead and open up a TAC. All the best !!
Hope this helps
Cheers
Rath!
