11-08-2018 03:33 PM
how to upgrade the firmware of cisco phone 7811 without using "Unified Communications Manager"?
do we need to have Unified Communications Manager or something similar to this in order to configure this model of cisco phone? I used to change the setting with browsing the ip address of other model of cisco phone.
right now it displays a "Welcome" screen with the text "Enter activation code or service domain", and I found out I need to upgrade firmware to fix the issue
I cannot browse the ip address of the phone. looks like it is disabled by default. how can I enable it?
11-08-2018 03:35 PM
11-08-2018 04:02 PM
you said it is loaded with 3PCC/MPP firmware, so what do you mean I need to find 3PCC/MPP firmware then if it already has that firmware?
any idea about the web access?
11-08-2018 04:03 PM
11-09-2018 02:58 PM
I have setup tftp and dhcp option 150.
looks like it is able to connect the tftp server
but it still says registration in progress.
when I look at the status message: it says:
no trust link installed ,
File not found sipphonbename.xml and
XMLDefault.cnf.xml.xml (TFTP)
11-09-2018 03:48 PM
Progress (in a sort of way).
Looks like Cisco has changed the way 3PCC behaves again.
XMLDefault.cnf.xml was an old, old method. Google this and you'll be able to find various examples how to make one.
NOTE: Are you sure it is looking for a filename called "XMLDefault.cnf.xml.xml" (with the file extension gets repeated)?
Filename "sipphonbename.xml" is the first I've seen this behaviour.
11-09-2018 03:58 PM
the xml file name is correct. I just did not provide the right name in my previous post.
I found the file here:
https://www.ukvoipforums.com/viewtopic.php?t=1113
can you please confirm if this is the right one?
11-09-2018 04:00 PM
11-09-2018 04:01 PM
so why it is not doing anything, it should say something about upgrade on screen right?
11-09-2018 04:05 PM - edited 11-09-2018 04:06 PM
You need to do a factory-reset for the phone to start downloading everything again, including the new file you've created. It's a "Cisco" thing.
In the past, old firmware will hit the TFTP server very often. New firmware doesn't do this anymore.
Another thing, you may need to create TWO (2) XMLDefault.cnf.xml files. One has the filename of "XMLDefault.cnf.xml" and the other has the filename of "XMLDefault.cnf.xml.xml".
Pay attention to which one gets downloaded by the phone. If it's the one with two "xml", then it's clear cut it's a bug.
11-09-2018 04:15 PM
actually is not two files only one xml file.
before setting up this upgrade it said the last update of phone was for last year and now it says for today date.
but why it cannot load anything on screen. still says it is registering....
why I cannot browse the phone with IP address with a browser?
I do not have call manager server. and I want to setup phones standalone
11-09-2018 04:53 PM
11-09-2018 05:20 PM
Can you have a look at THIS.
See if you can make configuration changes by logging into the phone's web page:
Access the phone web page from a web browser on a computer that can reach the phone on the subnetwork.
If your service provider has disabled access to the configuration utility, contact the service provider before proceeding.
Step 1 |
Ensure that the computer can communicate with the phone. No VPN in use. |
Step 2 |
Start a web browser. |
Step 3 |
Enter the IP address of the phone in your web browser address bar.
For example, |
