configure & troubleshoot anyconnect
156
Highlighted
Beginner
Cisco 7811 robotic voice
Hi Community,
I was having a issue wherein two of my CP-7811 IP phones the audio quality was bad wherein the audio sounds like "robotic" sound. I have seen work around wherein "Disable Opus codec support via Service Parameters on CUCM." but it seems that the version of my call manager is not hitting the bug. I'm not sure what other things i must check to fix the issue. Do i need to configure the QOS of my router or do i have to check other things
Thank you appreciate you all community.
Everyone's tags (1)
6 REPLIES 6
omz Enthusiast
Enthusiast
Re: Cisco 7811 robotic voice
Check for packet drops/errors on the interfaces
Hall of Fame Cisco Employee
Get a sniffer from the call, if it sounds OK then it might be a problem with the device/FW, if it already arrives sounding robotic, you'll need to find out if it might be the other end having the problem, or if something in the network might be causing that.
You can try with a different FW to find out if it's the device or not.
java
if this helps, please rate
Rising star
Follow below guide
https://www.cisco.com/c/en/us/support/docs/voice/voice-quality/211299-Troubleshoot-Voice-Quality-Issues.html
The first step will be to find out where the robotic voice is originating, so you need to take packet captures to verify same.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Beginner
Hi All,
Thank you for the help. the issue was resolved after we tried to re-insert the Plug of the IP phone, However we are monitoring the behavior of the phone if the issue will still persist.
Rising star
Good to know that, so the issue was due to a loose connection?
Haris
Beginner
I'm not sure about that, and the issue is weird since the robotic sound will re occur after a month randomly to other phones.
