Cisco 7841 SIP phones dont accept digit while setting up the voicemail
nitesz010
Hello Everyone,
I am using CME-CUE with 7841 SIP phones. I have all the configurations done for the voicemail. When dialing into the voicemail, it starts with the prompt, " Welcome to CIsco Unity Express.......To record a new name press 1, to keep the recorded name press #." I doesn't take the keypad entry whether I press "1" or "#". The prompt continues and ends with the goodbye message. Please help.
10 Replies 10
Vivek Batra
Please share the configuration.
- Vivek
Ayodeji Okanlawon
This looks like a DTMF configuration issue. For DTMF to work, you need the following
1. Configure DTMF for the phone
voice register pool xx
 dtmf-relay rtp-nte sip-kpml
2. Configure DTMF on the dial-peer to CUE
dial-peer voice xx voip
 session protocol sipv2
  dtmf-relay rtp-nte
  codec g711u
3.Configure DTMF in CUE
ccn subsy sip
dtmf-r rtp
Please rate all useful posts
Hi Deji, is latest CUE release supporting inband DTMF?
Hi Vivek,
Yes it does.
Can you please share any reference document mentioning the same if you have it....
Here you go
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/administrator/AA_and_VM/guide/vmadmin_book/syscmp.html#wp1011720
As of five years ago, this threads indicates that it supports rfc2833
https://supportforums.cisco.com/discussion/11189151/cmecue-sip-phones-dtmf-relay
Thanks D (+5).
Thanks Ayodeji. I actually had the dtmf configurations mentioned above. To solve this issue I actually had to go the voice register pool XX and add dtmf-relay rtp-nte. I thought that would be by default. But I still have the MWI notification issue. I cant get the lamp or the envelope sign on when someone leaves a voice message. I am using SIP unsolicited method.
sip-ua
 mwi-server ipv4:x.x.x.x expires 3600 port 5060 transport udp unsolicited
(where x.x.x.x is the ip add of the unity express)
On the Unity Express side I have
ccn application ciscomwiapplication aa
 description "ciscomwiapplication"
 enabled
 maxsessions 10
 script "setmwi.aef"
 parameter "CallControlGroupID" "0"
 parameter "strMWI_OFF_DN" "8001"
 parameter "strMWI_ON_DN" "8000"
 end application
Moreover I have created two dn's for mwi on and off under telephony service.
ephone-dn  19
 number 8000.... no-reg both
 mwi on
ephone-dn  20
 number 8001.... no-reg both
 mwi off
# sh ccn subsystem sip
SIP Gateway:                            x.x.x.x (IP add of the CME router)
SIP Port Number:                      5060
DTMF Relay:                             sip-notify,sub-notify
MWI Notification:                       unsolicited
MWI Envelope Info:                   enabled
Transfer Mode:                          bye-also
Transfer Timeout :                      6
SIP RFC Compliance:               Pre-RFC3261
You don't need mwi dn if you are using unsolicited. I believe this is used for outdial..the old method
You need mwi configured on the DN of the phone..
voice register dn  xx
mwi
I took off the ephones. Still no luck.Is there anything I need to do beside this?
voice register dn  1
 number 1001
 call-forward b2bua busy 500
 call-forward b2bua mailbox 500
 call-forward b2bua noan 500 timeout 18
 name Phone 1
 label Phone 1
 mwi
voice register dn  2
 number 1002
 name Phone 2
 label Phone 2
 mwi
