Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco 7861 phone does nothing when you press the corporate directory button: just blank screen and no error message
Sarg .
Level 3
Level 3
Hello everyone,
we recently deployed some Cisco 7861 (78xx.10-1-1SR1-4) phones running on cucm 9.1.2.10000-28 . What we have noticed is that after a while, the corporate directory stops working. But if we reboot the phone, it starts working again.
Another thing we noticed is that when the phone stops access corporate directory, the phone's webpage stops working but if you reboot the phone, then you can access the phones web page again.
Cisco actually tried to enable debugs while the phone was broken but the phone did not produce any logs, but if you reboot the phone, then it starts producing logs.
I have a TAC case for but I just wanted to find out if there are other people here facing this same problem. with 78x phones?
Maxwell
15 Replies 15
Kator
Hi Maxwell
I have a very similar problem.  When pressing the phone book, nothing is shown on the display.  Neither the "Corporate directory" nor the "Personal address book" opptions apear.  Nothing is displayed.
We are running CUCM 8.6 and installed the latest Device Package.  The phones use sip78xx.10-1-1SR1-4.  I have seen the same problem on 7841 and 7861 phones.  I haven't reported to Cisco yet, but I am intending to.
you should, i have been hearing that this problem is rampant. The problem exist on three sites that we have installed this phone. and yes, 7861and 41 uses the same firmware
i have similar issue with 7841 firmware sip78xx.10-1-1SR1-4  cucm 9.1.2.10000-28.
i tried this configuration:
i configured under device-->phone :
External Data Locations Information (Leave blank to use default)-->
Secure Directory URL--> https://PublisherHostName:8443/ccmcip/xmldirectory.jsp  ; AND
Services ProvisioningRequired Field-->external URL
when i press directory button i see phone display as attached figure.
do i need to wait for a new firmware ?
thanks
Cisco never ended up fixing it - seems too ad-hoc/random to catch in the act properly, combined with the new SSH for debugging, made it frankly too difficult to troubleshoot and a PITA - we'll have to wait for a while and test with another firmware, in the mean time we stopped recommending them to our customers.
Hi Team,
i have the same issue on 7841 with firmware sip78xx.11-5-1-18 and call manager version 9.1, from application menu i can access the directory but from button on the phone it is showing nothing,(just a lock symbol on the top right side), can anyone help me??
Hello all,
I have the same issue on 7821 and 7841. It works fine on 8831, 8851, ...
Did you resolve it?
Thanks for your feedback.
I have the same issue. Did you fix it? How can i unlocked the corporate directory?
Hi Marco.
Can you do this test for me?
- Configure a non secure url pointing to corporate directory.
- Configure a span session on switch port where IP Phone is attached to.
- Put your pc an destination of monitor session and activate wireshark on your pc.
try to access corporate directory from that phone and capture the traffic.
Than post here  the result or if you want you can send me the file privately.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
it's a pleasure reading your replies ;).
Yes, changing from https to http corporate directory works. Your suggestion is the right workaround.
I noticed a strange behaviour on device phone web page configuration.
It seems URL Directory parameters are ignored by 7841 phones, and they always take into consideration those specified in enterprise parameters.
So i can get Corporate Directory working only if i delete Secure URL from enterprise parameters.
But our customer is not proud about this, and they want https.
bye
marco
Hi Marco
What exactly did you do to make this work partially?
i deleted Secure URL Directory in  enterprise parameters, so the phone take into consideration HTTP only for requesting corporate directory toward Publisher.
with http it works.
But i suggest first deleting certificates on the phone. Try deleting certificates on the phone first, without changing enterprise parameters, and let us know
bye
marco
Trust me,
The issue is not fixed my friend. A reboot always fixes the problem, but it never fails to return within two weeks.  When it fails, the phone browser may also crash too
This phone has been a massive pain to me.
cheers
Yeah we have this issue too - have logged with TAC but they have not found anything yet.
Other issues we have include:
- When on a call the volume does not show on the screen
- Sometimes after a call is complete the call window remains on the screen and is blacked out.
Hello Ian,
I had the same problem with volume too, but since upgrading to the latest version, it has been stable for me for about ten days now. However, the directory is still not working.  My employer actually has two TAC cases for the directory issue. In fact, one of the cases is with the phone development team for over two weeks and still no joy.
