Cisco 7912 registering to CUCM 14
rmeuchel
Does anyone know if a Cisco 7912 will register on CUCM 14? I know it's deprecated in an older version of CUCM. However, will placing and receiving basic calls still work (although it would not have security updates, bug fixes, etc.)? Or does the 7912 model type simply not exist if you try to add it to CUCM 14?
Thanks!
Russ
Existing phone if you are upgrading to 14 will show rejected and you will see a message on the login page.
new 7912 phones you cannot add on cucm 14
Response Signature
Thank you!
Russ
Jaime Valencia
Problem / Symptom
If you are running any of these phone models that have been deprecated, after you upgrade and switch over to the new release, registration will be blocked on the phone. If the phone remains powered on, the phone will make repeated registration attempts, which will create unnecessary network traffic as well as a load on the Cisco CallManager service.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/trouble/14_0_1/fieldNotices/cucm_b_deprecated-phones-14.html
java
if this helps, please rate
