cisco 7925 Unable to change "Web Access" to "Full"
amirgolan
hi all,
i need to change the "Web Access" field to "Full".
when i changed it and click "Save", after refresh that field doesn't change to "full" and stay on "Read Only"
i'm loged in whith an administrator user.
CUCM ver7.1
thanks.
Aman Soi
Are u following the below procedure:
Setting Configuration Privileges for the Phone Web Page
To make changes to the phone by using the web page, you must use Cisco Unified Communications Manager Administration to enable Web Access and Phone Book Web Access.
To allow configuration privileges, follow these steps:
Procedure
Step 1 Log into Cisco Unified Communications Manager Administration.
Step 2 Search for the phone in Cisco Unified Communications Manager Administration by choosing Device > Phone and enter search information such as the DN.
Step 3 Click on the DN of the phone that you want to set the privileges.
Step 4 Open the Phone Configuration window, scroll down to Product Specific Configuration Layout, and enable these privileges:
In the Web Access field, select Full from the drop-down menu.
In the Phone Book Web Access field, select Allow Admin.
Step 5 Click Save to make the change.
Step 6 You must reset the phone to enable configuration privileges on the web pages for this phone.
regds,
aman
hi,
i did it but still unable to change.
on cisco 7921 i am able to do it.
HI,
I was just referring this bug found in call manager 7.1.3
CSCtd92600 Bug Details
Apply Config to 7921/7925 sometimes failed
Symptom:
UCM sometimes does not send 'Reset' message to the phone after clicking Save, Apply Config buttons.
Conditions:
When changing the paramester value from Phone Configuration page for 7921/7925, after clicking Save, Apply Config and OK buttons, I observed the phone sometimes did not restart to update the configuration. I used sniffer to capture the traces and found UCM sometimes did not send "Reset" message with reset type 'DEVICE_RESTART" to the phone. This issue could happen when the phone was in idle. It's also easy to reproduce if did 'Apply Config' when the phone was in active call.
Workaround:
Restart the phone from CUCM.
can u restart phone and update?
regds,
aman
