12-14-2018 12:08 PM - edited 03-17-2019 01:50 PM
We purchased two 7925G units we want to use the hunt group logout/login feature. From the Cisco documentation the hunt group login/logout button should be under Option > HLog. We discovered the HLog button isn't available under options for some reason. The phones are using the standard SCCP template, we tried creating a new template but the HLog button isn't listed as on of the unused items. Can anyone tell me what is needed to add the hunt group login/logout button for this model of phone? Is this a firmware related issue? Any assistance would be greatly appreciated.
Solved! Go to Solution.
12-17-2018 11:00 AM
12-16-2018 06:31 AM
12-17-2018 10:23 AM
I attempted to add the HLOG button via the template but the HLOG option is not listed as a choice. Is there a reason why its not available? I have attached a screenshot of the template listing, how can I add the HLOG button to the template?
Thanks for any insight.
12-17-2018 11:00 AM
12-17-2018 12:20 PM
