08-29-2012 07:17 PM - edited 03-16-2019 12:56 PM
Hi everybody
I just want to confirm few things:
1) Does cisco ip phone 7940 with sccp firmware look for file OS79XX.TXT on tftp when first powers up?
2) Does cisco ip phone 7940 with sccp firware version upon resetting, look for SEPMac file for example
SEP003094C25D2E.cnf.xml where 94c25D2E is the mac address of the phone?
thanks
Solved! Go to Solution.
08-30-2012 07:33 AM
1. only with old frimware version when phone is factory reset.
2. yes.
08-30-2012 07:40 AM
Hi there,
Just a reference to the great tips from my friend Paolo (+5 "P" )
A protocol boot mechanism is used to select the firmware image. During the phone bootup, regardless of protocol, the first file requested is the OS79XX.TXT file. The OS79XX.TXT file includes a line that contains the image name of the protocol that you select to run. For example, the image should read P003xxyyzzww for SCCP, P0S3-xx-y-zz for SIP, or P0M3-xx-y-zz for MGCP.
The phone uses the first four characters in the image name of the OS79XX.TXT file to determine how to load the image. If the first four characters match, the universal boot mechanism is bypassed and the phone continues with its current protocol boot sequence. However, if the first four characters do not match (namely the third digit, which represents the protocol), the universal boot mechanism will attempt to load the new protocol image that has been defined in the OS79XX.TXT file.
The universal application loader allows for additional phone features to be added across all protocols. This feature also eliminates the need for a separate OS79XX.TXT file, which used to be required for booting between protocols.
The universal application loader operates in a manner very similar to the older SCCP, SIP, and MGCP systems. It relies on a TFTP server to supply information in text files known as "configuration files." The information in these files points to a new loads file, which contains the names of the desired application image and universal application loader. This system allows the universal application loader to know which image revision is desired in the phone. Once this information is known, the phone has the ability to upgrade itself and the application image as needed.
The universal application loader allows the system administrator to use SCCP, SIP, and MGCP, on the same network. To do this, a hunt algorithm is employed that searches for multiple configuration files. Depending on which configuration file is found first, the phone will automatically select that protocol. The hunt algorithm ensures that the administrator can assign a specific protocol to a specific phone. The hunt algorithm searches for files in the following order:
1. CTLSEP MAC File—For example, CTLSEP003094C25D2E.tlv. See the "Secure and Nonsecure Configuration" section.
2. SEP MAC File—For example, SEP003094C25D2E.cnf.xml.
3. SIP MAC File—For example, SIP003094C25D2E.cnf.
4. MGCP MAC File—For example, MGC003094C25D2E.cnf.
5. XML Default File—For example, XMLDefault.cnf.xml.
6. SIP Default File—For example, SIPDefault.cnf.
7. MGCP Default File—For example, MGCDefault.cnf.
The universal application loader is also capable of searching multiple servers to find the configuration files, using DHCP, manual settings, and Domain Name System (DNS). The configuration file can also contain a dynamic_tftp address, which will force the phone to use a different server.
If the universal application loader exhausts all possible servers and still cannot find any configuration files, it will assume that the application image in flash memory is correct and will launch it. If it cannot find an application image in flash memory, it will stop and display "No Load Specified" on the screen.
The loads file contains the universal application loader and the application image, as well as an LA_VERSION command (used to determine if the universal application loader needs to be upgraded). The universal application loader is identified by its extension (.sbn), which indicates that it is signed. The signed application image is identified by a .sb2 extension. The loads file itself is also signed and has a .loads extension.
Cheers!
Rob
"Every fool's got a reason to feelin' sorry for himself" - Springsteen
08-31-2012 12:41 AM
No, as mentioned above, it will not look for tha file, that is now obsolete.
Thank you for the nice rating and good luck!
08-30-2012 07:33 AM
2. yes.
08-30-2012 07:40 AM
Hi there,
Cheers!
Rob
08-30-2012 11:48 PM
Thanks Rob and Paolo
So what do kind of behavior we expect from modern cisco ip phone upon powering on? Will they look for OS79XX.txt file on tftp server? I understand that when we reset the phone, the phone will look for specific file on tftp server for example SEP mac file if the loaded firware is sscp. But that is only when we reset the phone. What if we not reset the phone and simply power it up , will it look for OS79XX.txt file?( Considering only cisco ip phone with latest firware)
thanks
08-31-2012 12:41 AM
