Cisco 7940 - View caller contact stored on phone
W. S.
Beginner
Beginner
When someone calls from external numer and I have stored contact on phone (cisco 7940), It's display only number not contact name. How I can change it, i try find answer on documentation but I didn't find anything.
Terry Cheema
Advocate
Advocate
CUCM can not do this, its a limitation. It can be done on the gateway using some advanced TCL scripting on the router but complex and with limitations.
If you are using CUCME then certainly its possible.
-Terry
I don't use CUCME. I'm using Asterix.
Recognize Your Peers
