05-19-2015 12:36 PM - edited 03-18-2019 11:32 AM
Hi All,
I have a cisco 7942 phone that is 4hrs ahead in the time. Also a cisco 7821 is getting the correct time. I check the phone load and its not getting the correct phone load from the call manager. It keeps getting "auth fail" when trying to download. I suspect it is related to the phone loads. Can someone advise how I can force the phone to get the phone loads from the cucm?
05-19-2015 02:28 PM
What is the current 7942 firmware and what should the 7942 firmware be?
According to the compatibility matrix below, the firmware version should be 9.3(1) SR4.
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
If you have recently upgraded there may be a firmware upgrade that is needed before you can jump to 9.3(1)SR4.
05-20-2015 06:12 PM
HI,
What is the current phone load on the phone? Try going back to 8-3-3SR2S for that particular phone and then move to the current default set in the call manager.
John
