Cisco 7945/65 Won't Register After CME Reboot
hismartalarms
I am officially stumped. I am running IOS 15.1, and CME 8.6 on my 2911. I have my CME router inside my main network (WatchGuard Firewall), and one of the interfaces on the CME router set as a WAN connection. My phones are also plugged into the WatchGuard network. I also have DHCP option 150 set in my WatchGuard router pointing it to the CME router, so the TFTP address is correct. (Basically, phones talk outside of the CME router).
When I first setup and configured the CME, everything works fine, phones register fine, and everything is great. After saving the config and rebooting the router, no phone will register to the CME router. They will pull TFTP files, firmware, SEP<MAC_ADDRESS>.cnf.xml files just fine, but they just get stuck saying "Registering" on the phones.
The phone can talk to the CME router, the CME router can talk to the phone, if I look under the phone's settings, all of the settings are correct. (Valid IP, Correct TFTP server IP, Correct Unified CM 1 Server IP, correct firmware, no error status messages).
I have even pulled the TFTP files manually using TFTPD from the router and inspected the configuration files, nothing stands out. No weird IPs, no weird ports, nothing.
I am stumped. This happens every time I reboot it. (I have reset the configuration and started from scratch twice, still with the same results).
I have even tried putting the phone inside of the network, still no luck.
Any suggestions are appreciated. Thanks.
Edit: I have tried manually creating cnf-files. No luck. And the time is incorrect on my router,  so ignore the dates from 2002
Configuration:
show run
Building configuration...
Current configuration : 4288 bytes
! Last configuration change at 21:48:53 Eastern Sun Dec 18 2022
version 15.1
service config
hostname hsl-cme
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
enable password <YOU DON'T NEED THIS LOL>
no aaa new-model
clock timezone Eastern -5 0
no ipv6 cef
ip source-route
ip cef
voice-card 0
voice service voip
 no ip address trusted authenticate
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
voice register global
 mode cme
 create profile sync 0012570042340388
voice translation-rule 1
 rule 1 /3238/ //
voice translation-rule 2
 rule 1 /9\(.......\)/ /\1/
voice translation-profile SIPstrip
 translate calling 2
 translate called 2
voice translation-profile SIPto3DIGIT
 translate called 1
license udi pid CISCO2911/K9 sn FTX1842ALHV
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address 10.0.0.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
no ip http secure-server
ip http path flash:/cme-gui-8.6.0
ip route 0.0.0.0 0.0.0.0 172.16.0.1 254
ip route 0.0.0.0 255.255.255.0 GigabitEthernet0/0
tftp-server flash:apps45.9-2-1TH1-13.sbn
tftp-server flash:cnu45.9-2-1TH1-13.sbn
tftp-server flash:cvm45sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp45.9-2-1TH1-13.sbn
tftp-server flash:jar45sccp.9-2-1TH1-13.sbn
tftp-server flash:SCCP45.9-2-1S.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
control-plane
voice-port 0/1/0
 timing digit 50
 timing inter-digit 50
 connection plar 380
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp profile default
dial-peer voice 100 voip
 translation-profile incoming SIPstrip
 translation-profile outgoing SIPstrip
 destination-pattern 9.......
 translate-outgoing calling 2
 translate-outgoing called 2
 session protocol sipv2
 session target <YOU DON'T NEED THIS EITHER LOL>
 codec g711ulaw
dial-peer voice 102 pots
 destination-pattern 381
 port 0/2/0
dial-peer voice 99 voip
 translation-profile incoming SIPto3DIGIT
 incoming called-num
 codec g711ulaw
dial-peer voice 1000 pots
 destination-pattern .%
 port 0/2/0
sip-ua
 credentials <YOU DON'T NEED THIS EITHER LOL>
 authentication <YOU DON'T NEED THIS EITHER LOL>
 registrar 1 <YOU DON'T NEED THIS EITHER LOL>
 sip-server <YOU DON'T NEED THIS EITHER LOL>
gatekeeper
 shutdown
telephony-service
 max-ephones 15
 max-dn 100
 ip source-address 172.16.0.112 port 2000
 system message HSL Research
 cnf-file location flash:
 cnf-file perphone
 load 7945 SCCP45.9-2-1S.loads
 load 7965 SCCP45.9-2-1S.loads
 max-conferences 8 gain -6
 web admin system name <YOU DON'T NEED THIS EITHER LOL>
 dn-webedit
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
 number 380
 label Line 1
 description 380
 hold-a
ephone  1
 device-security-mode none
 mac-address 5897.1E28.50C6
 speed-dial 1 <FORUMS DON'T LIKE PHONE NUMBERS> label "P-Star CSM"
 type 7965
 button  1:1
 pin 1379
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
ntp server 132.163.97.5
end
If I'm reading your config right, the last time you issued create cnf-file under telephony-service was 2002? Or is your NTP off?
Regardless, please issue create cnf-file and see if that fixes the issue.
Maren
Time server is off. I have issued the cnf-file multiple times, I have even tried deleting the previous files and creating them again.
