Cisco 7945 and VPN Client: minimum requirements?
raziel78kain
Explorer
Explorer
which are the minimum requirements to get the VPN Client on a Cisco 7945?
  • Minimum firmware version on Cisco 7945
  • Minimum CUCM version
  • Other requirements
TIA and regards.
2 ACCEPTED SOLUTIONS
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
CUCM 8.0(2) and the rest of the info is here:
Cisco Unified Communications Manager Security Guide,  Release 8.0(2)
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/security/8_0_2/secugd/sec-802-cm.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Brett Fritzsch
Also,  this is a great document on requirements and setting up/troubleshooting the phone VPN client:
https://supportforums.cisco.com/docs/DOC-9124#Software_Versions
Hope this helps!
-Brett Fritzsch
2 REPLIES 2
Jaime Valencia
java
java
Brett Fritzsch
Hope this helps!
-Brett Fritzsch
