01-27-2016 11:44 AM - edited 03-17-2019 05:38 AM
All,
Basic question I know... Am I not able to dial alpha characters from a Cisco 7960 endpoint?
D
Solved! Go to Solution.
01-27-2016 01:46 PM
Uniform Resource Identifier Dialing is an enhancement supported with Cisco Ip phone 8961,9951 and 9971 . However, it is not supported on Cisco Ip phone 7960.
Kunal
01-27-2016 12:57 PM
what is the need of dialing alpha character ? is it for routing ? I am assuming you not meant for entrying PIN, unlocking/locking phone etc ... AFAIK its is not programmed in this way to dial-out alpha character.
01-27-2016 01:21 PM
I am trying to do URI Dialing from the 7960. Works all OK with Speed Dials.
D
01-27-2016 01:46 PM
Kunal
01-27-2016 02:04 PM
Dial:N is not supported on Generation one Phone ie 7960/7940.
https://tools.cisco.com/bugsearch/bug/CSCsy52327/?reffering_site=dumpcr
