Cisco 7960G and 7970 G SIP Phones connection to Astrisk
jarivera2000
I currently am trying to troublesjoot a problem where I have 4 7960G SIp Phones and one 7970G phone connected to an Astrisk system . The phone can make calls out but will not receive calls inbound. Any ideas on what can be wrong?  I have used GrandStream, Yw600, and Linksys phone on the same ports with no problems. Thank You for the help.
Justin Brenton
Level 4
Level 4
Hi Juan,
I would check for Codec mismatches or dialpeer issue's.
Check your dial peers to see what codecs are assigned (if any).  I'm not sure what codecs the server supports but that is where I would start.
HTH, Please rate if so.
Justin
www.ucintegrations.com
