Cisco 7962 Corporate Directory - not working says to Contact Administrator
ereyno001
Level 4
Level 4
I recently bought 350 Cisco 7962s for UCM 7.X of those 350 about 100 of them I cannot access our corporate directory. I get an error saying to contact the administrator.
I have tried to do the factory reset; there are no Config differences between the phones that work and the phones that do not work, Same Firmware, Same Subnet, and same UCM Config, I know this for sure as I used the same bulk template for them all.
Just wanted to see if anyone else has seen this, our next step is to update the firmware but I did not want to do firmware updates during our busy season in case that causing any other issuers.
Ed
Not sure if this bug has something to do with your issue
CSCte05181 Bug Details
Blank Page if corporate directories is pressed during requesting mode
Symptom:
On the CM 7, users press the directories button, the personal and corporate directories are available while "requesting" is displayed. If the users press either 4 or 5 to get one of these options while the "requesting" shows on the screen, they get a blank page that does not away.
Conditions:
none.
Workaround:
none.
StatusStatus
Fixed
(Verified)
Severity Severity
3 - moderate
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified IP Phone 7900 Series
Technology Technology
1st Found-In 1st Found-in
8.4(2)
Fixed-In Fixed-in
9.0(3)MN1.10
Component(s) Component
sw-phone-jphone
Regression Regression
Y
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
22 Replies 22
Graham Old
Level 7
Level 7
Is that when you press the Directories button or when you try to select Corporate Directory
Graham
Only after pressing the Corporate Directory. At first I was thinking LDAP issue, but I have nearly 1000 other phones that do not have an issue and a little under 200 7962s that are okay.
Strange
The only thing I can suggest is make sure the "Span to PC port" is on for the phone. Load Wireshark onto the PC plugged into the back of the phone and capture the network traffic between the Phone and CUCM.
Whatever URL the phone is accessing you should be able to put into IE and see the XML results back from CUCM
Graham
Can you look at the phone settings ---> Device config ---> HTTP Config
What does the Directies URL show ?
Alex
it is the same on all phones, working and non working
Http://10.8.224.21:8080/ccmcip/xmldirectory.jsp
the IP is the IP of our PUB.
I can get to this address from the PC that the phone is connected to and from any other PC...
this is what I get... so that appears to be working.
  Select a directory
Well at least that proves it does NOT look like a DNS problem.
Are all the phones that dont work in the same vlan/subnet, I know you said that you
can reach the URL from a PC in the back of
the phone but that will probably be on your DATA subnet/vlan not the VOIP vlan.
Alex
On the subnet, there is a mix of phones that work and do not work, the strage thing here is I can pull the 7962 out and put in a 7960 or 7940 and it works. I am only seeing this on a handful of Cisco 7962s.
Could you try to factory reset ONE 7962 phone
Step 1 Unplug the power cable from the phone and then plug it back in.
The phone begins its power up cycle.
Step 2 While the phone is powering up, and before the Speaker button flashes on and off,
press and hold #.
Continue to hold # until each line button flashes on and off in sequence in amber.
Step 3 Release # and press 123456789*0#.
You can press a key twice in a row, but if you press the keys out of sequence, the factory reset will not take place.
After you press these keys, the line buttons on the phone flash red and the phone goes through the factory reset process.
Do not power down the phone until it completes the factory reset process and the main screen appears.
Alex
Good thought, but ... still the same.
its very strange, I am hoping a firmware update will do it but I have my doubts.
Symptom:
Conditions:
none.
Workaround:
none.
StatusStatus
Fixed
(Verified)
Severity Severity
3 - moderate
In Last Year
Product Product
8.4(2)
Fixed-In Fixed-in
9.0(3)MN1.10
sw-phone-jphone
Y
Alex
This does look similar, I will investigate. Thank you so much for all your help so far!
Alex thank you so much this looks like it is the issue. I have the firmware, I will get this updated.
Graham thanks for your help too!
Upgraded to the latest Firware Version 9.2(3)
Still NO Corporate Directory... really strange
That bug really looked similar so I guess I just jumpped the gun or just wishful thinking.
I am going to open a TAC on this one and I will update this string when it is fixed.
If you want to collect a Wireshark trace and post it I will have a look at it.
Graham
