280
Rising star
Cisco 7965 hardware rev 15 is not supported on CME?
Hi everyone,
I have a doubt regarding CME supported firmware. I'm running CME 8.6 on Cisco Router 2811.
For 7965 and 9971 phones running CME 8.6, Cisco recommend to run Firmware SCCP45.9-1-1SR1S.loads and sip9971.9-1-1SR1.load but phone with hardware revision 12.0 and higher doesn't support firmware earlier than Release 9.3(1)SR1.
Today I downloaded firmware  cme-153-2Tv1.rar recomended for CME 10.5 (already know is not supported on 2811) but firmware attached are SCCP45.9-2-1S.loads and sip9971.9-2-2SR1-9.loads, they are earlier than Release 9.3(1)SR1.
Am I missing something? Doesn't CME support new phone hardware or file name is not related with firmware version?
Cisco Unified CME 8.6 Supported Firmware, Platforms, Memory, and Voice Products
Cisco Unified IP Phone7945G and 7965G
apps45.9-1-1TH1-16.sbn
cnu45.9-1-1TH1-16.sbn
cvm45sccp.9-1-1TH1-16.sbn
dsp45.9-1-1TH1-16.sbn
jar45sccp.9-1-1TH1-16.sbn
SCCP45.9-1-1SR1S.loads*
term45.default.loads
term65.default.loads
Cisco Unified IP Phone9971
dkern9971.100609R2-9-1-1SR1.sebn
kern9971.9-1-1SR1.sebn
rootfs9971.9-1-1SR1.sebn
sboot9971.031610R1-9-1-1SR1.sebn
skern9971.022809R2-9-1-1SR1.sebn
sip9971.9-1-1SR1.loads*
Cisco CallManager Express 10.5 Supported Firmware, Platforms, Memory and Voice
SCCP45.9-2-1S.loads
apps45.9-2-1TH1-13.sbn
cnu45.9-2-1TH1-13.sbn
cvm45sccp.9-2-1TH1-13.sbn
dsp45.9-2-1TH1-13.sbn
jar45sccp.9-2-1TH1-13.sbn
dkern9971.100609R2-9-2-2SR1-9.sebn
kern9971.9-2-2SR1-9.sebn
rootfs9971.9-2-2SR1-9.sebn
sboot9971.031610R1-9-2-2SR1-9.sebn
skern9971.022809R2-9-2-2SR1-9.sebn
Phone
Hardware Version
Cisco Unified IP Phone 7942G
15.0 and higher
Cisco Unified IP Phone 7962G
15.0 and higher
Cisco Unified IP Phone 7945G
13.0 and higher
Cisco Unified IP Phone 7965G
13.0 and higher
Cisco Unified IP Phone 7975G
12.0 and higher
Phones manufactured with these hardware versions must run Firmware Release 9.3(1)SR1 or later. The phone firmware does not allow the phone to be downgraded to releases earlier than Release 9.3(1)SR1.
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
1 ACCEPTED SOLUTION
Hall of Fame Community Legend
Hi Leo,
Hi Leo,
Hope all is well my friend!
The docs like this one for CME only show the recommended firmware at the time the CME version was released. You would be fine to download and install a newer firmware like 9-3-1sr4 or higher that can support the 7965's with hardware rev 15. These docs are not updated to reflect new firmware versions.
Just use the .zip firmware file from this path;
Skinny Client Control Protocol (SCCP) Software-9.3(1)SR4
Cheers!
Rob
4 REPLIES 4
Hi Leo,
Hi Leo,
Cheers!
Rob
Rising star
Thanks Rob my friend! As
Thanks Rob my friend! As always an excellent answer(+5).
Highlighted
Beginner
Re: Hi Leo,
Greetings All
Hi Leo,
Hi Leo,
Always a pleasure buddy!
Cheers!
Rob
Content for Community-Ad
August's Community Spotlight Awards
